This is my first post to this forum, which I have found very helpful.
I live in southern Finland where the roads are salted every winter causing rusting and corrosion.
The car mechanically is in working condition, with about 210 000 miles on it. The electrical problems have been growing with the last few years. Initially, in the winter the car would blow the fuses of our house when connected to block heater via external cable. About a half year later the V70 started dimming lights while driving. For example, If I were to lower my window, the headlights and the interior lights would dim.
This winter the headlights have been acting very oddly, sometimes when starting, the headlights would not turn up until switching it on and off fiercely. Also the engine would drop below from the normal 1000 rpm to about 500 rpm when coasting, sometimes even stalling. Now the headlights stay on even when the engine is not running and the doors are shut. I have overcome this by taking the headlight fuse of when parking, but I reckon that something should be done.
From my understanding, could this be a grounding issue? Or maybe the CEM unit is at fault with malfunctioning lights?
Thanks in advance for all the responses. I have found topics regarding some of these problems, but not all.
Any advice would be helpful
