I am having a hard time getting a clean reading on the dipstick in my '00 V70 XC, 125,000 miles. I have followed Robert DIYs instructions too.
Engine is warm (3 o'clock on the gauge), transmission is warm. I remove and wipe the dipstick, reinsert all the way (with the click). Pull it out, and there is fluid splashed all over the dipstick. Can't tell if its in the correct range on the hot side or cold side.
Car runs and shifts fine. I do have some fluid leaks - possibly transmission and/or power steering, and minor oil seepage or consumption.
Could the transmission have been overfilled?
I do have a hard time finding a good level surface (wife gets the garage spot), but get the same result when on a level surface.
Dumb question - transmission fluid level
FlyingVolvo
- Year and Model: 2000 V70XC
- Has thanked: 51 times
- Been thanked: 74 times
Yeah, the trans dipstick reading can be a pain. Definitely try and get a flat surface, warm car, and cycle through the gears a bit. I clean off the dipstick as best as I can, put it back in fully seated and pull it back out immediately. Checking only the "hot" side, there may be some splash, but you should be able to tell where the solid fluid turns to more splattered... that's where I consider the level to be.
If truly in doubt, or you think it is overfilled... drain out the fluid and refill with 3.5 quarts (I personally recommend Mobil 1 Synthetic ATF). The drain & fill method drops out ~3.5 quarts (or more if overfilled) out of the ~8 quarts in the system.
2000 V70XC - 340,000 miles
2023 V60 T8 PE
2023 V60 T8 PE
- 2355 Views
Last post by j-dawg
- 1710 Views
Last post by precopster
- 1963 Views
Last post by Craigd2599
- 2458 Views
Last post by shiloh51933
- 2120 Views
Last post by BrianV70
