Hi there
im new to the volvo scene. I bought a 94 850 t5 abt 2 weeks ago and I have been searching high and low
to sort out the speedo. Ive been looking on the gearbox for the plug but cant find any pickup. only the reverse
on the top according to my searching I think i have a m56 gearbox in. the guy i bought it from says it was an auto
I found a 2 pin red plug on the gearbox side with grn/ye and ye/brn wire and according to wiring diagram that is
speedometer sensor.
Now my Q is how do get the speedo to work if it was a manual swop.
auto to manual swop speedo pickup
PurpleSnow
- Year and Model: 1994 850 T5 sedan
- Has thanked: 1 time
Volvo 850 T5 1994 Still deciding
Subaru legacy Wagon 1993 (Swopped) Problems
VW Jetta mk3 CLX 1998 (Swopped) Rust bucket
VW Golf mk4 2.0 (Seazed) Worst Borrow
VW Golf MK2 GTi 1987 (sold) FUN
VW Golf CTi 1993 (Sold) FUN
Ford Escort Sport 1977 (Sold) Project
VW Bug 1971 (Sold) Worst buy
Ford Escort Sport 1978 (Stolen) Perfect
tryingbe
- Year and Model: None
- Been thanked: 26 times
Vin number will tell you if the 850 was auto or manual from the factory.
If the car was manual swapped, and the transmission was from a later model 850, all you have to do is ID the vehicle speed sensor wiring from the car, cut the VSS connector off, extend the speed sensor wiring (2 wires, signal and ground), and splice it to the driver side ABS wiring (2 wires, signal and ground). Use the multi-meter to figure out which of the two wires of the VSS is ground and signal, and do the same ABS wiring.
85 GLH, 367 whp
00 Insight, 72 mpg
00 Insight, 72 mpg
PurpleSnow
so if i understand correctly i take the 2 wires that was connected on the gearbox speed sensor and splice them into the driver side abs sensor wiring. and that will work.
is there gearboxes that dont have speed sensors on the box itself
do they pickup from the abs sensors
sorry i know these questions are bit stupid
PurpleSnow
oh and ive looked around and i dont think this was a auto to manual swop. i just think it is a swop due to failure or something. i cant find anything that tell me it was a auto previously.
PurpleSnow
tnanx for all the help guys. will try that over the weekend and give update
PurpleSnow
ok i spiced the wires to the drivers side abs sensor. earth and sensor as far as i can figure.
but still no speedo reading. I have been seing the abs light since i got the car. should I swop out sensors from pass side and see what happens.
PurpleSnow
ok my bad one wire didnt have comms all the way for some reason. it works now, ill just double check with gps tomorrow.
now all the functions work on the car.
another question regarding the odo the small gear inside the cluster running the odometer. can you get that or should i opt to maybe 3d print it. dont think i will be able to find a cluster for parts here.
- Has thanked: 2197 times
- Been thanked: 1851 times
The odometer gears can be bought for not a huge amount. There are 2 or 3 vendors out there. FCP Euro used to list it and I think IPD also. The manufacturer also sells direct I think.
https://www.ebay.com/itm/VOLVO-850-ODOM ... 1168921107
https://www.ipdusa.com/products/4710/10 ... meter-gear
https://www.fcpeuro.com/products/volvo- ... ed-850gear
Last 2 are the cheapest.
There is also a couple of Youtube videos on how to fix.
AaronsVolvo
- Year and Model: 1999 V70
- Has thanked: 11 times
I do not want to question what you are doing, but what other problems does your car have?
You said the ABS light is on, any other lights?
It may be something else causing your speedo to stay dead, not necessarily poor wiring.
I could be wrong though.
- 298 Views
Last post by RickHaleParker
- 13 Replies
- 1168 Views
Last post by vtl
- 1203 Views
Last post by vtl
- 77 Views
Last post by chaosrob
- 18 Replies
- 5530 Views
Last post by not2old
