My car is makingn a metallic, fast-paced ticking noise similar to the one in this video:
From asking generic (non-Volvo) advice elsewhere, I was told normally you'll need to do a valve adjustment. However when I google valve adjustment, they say that you don't need to do it if you already have newer engine with "self-adjusting, oil-pressure-driven hydraulic lifters". I search a bit more and it looks like mine (1994 850) is the kind with hydraulic lifters. (Right? I'm not sure myself, just guessing from what's in this video: So is there still something to adjust, or nothing at all to eliminate that noise?
If there's something I can do, then what will it be? Do you have some instructions? What parts should I look for? I saw some rough mention here, (for example: viewtopic.php?f=11&t=47769), but nothing specific about the steps or parts. Do I need a gasket? Is there a valve cover gasket? What precaution should I take when taking off the valve cover? (I assume I need to keep the two camshaft position unchanged, but can I just leave the timing belt on? Leaving it on will help if I need to move the camshaft to measure some clearance, I assume.) Lack of picture also makes it hard to visualize.
If I don't need to do anything, then will it have any long term effect on the lift of the engine? Mine is around 220K miles right now.
Fast ticking sound: Do I need to do valve adjustment?
- Clemens
- Has thanked: 498 times
- Been thanked: 228 times
They use hydraulic lifters in 850ies. No need to adjust them. If your oil is dirty, you might get away with an oil change. Also, try to rev the engine beyond 4000 Rpm in gear, this usually helps to free stuck lifters in my 94
1996 855 R,
2010 V70 D5,
2010 V70 D5,
- FLXC90
- Year and Model: 98 V70 T5
- Has thanked: 16 times
- Been thanked: 45 times
First ensure your oil level is adequate. Try listening through a mechanics stethoscope or some tubing to determine if it is localized to certain lifters, or all of them. If it is all of them, you may need to replace the O-rings for the passages from the oil pan. If they fail, oil doesn't feed properly to the top end of the motor. Eventually, this will kill the motor.
+1 to the oil change, also try seafoam or other cleaners in the oil one time.
Current Volvos:
- Has thanked: 311 times
- Been thanked: 817 times
No valve adjustments, no lifter adjustments. As mentioned, it is extremely common for the o-rings inside the oil pan to be compromised by this stage (200k and 20 years) in these cars, and that's likely the problem here.
You can wait until the low oil light starts to flicker at startup, or if you intend to keep the car a long time and can handle a masochistic weekend then go ahead and drop the oil pan to do the job. Or just let it go and drive it into the ground. The suggestions about oil and Seafoam may help.
- callahanoffroad
- Year and Model: 1995 850
- Been thanked: 53 times
I'll ask the follow up question, if it's localized to a few valves only, then what is the solution?
Author, Chef, and Shade Tree Mechanic
1995 Volvo 850, Non-Turbo, VVIS, LH FI, Green, 215,000 miles. B5254FS engine. Herman. viewtopic.php?f=1&t=84393
1996 Volvo 850, died at 280,000
Founder of: CookingForChemo.Org
Read my Silly Comic Book at: therealpizzabros.com/
You could try a Seafoam treatment followed by changing the oil. If truly localized to a vale or two then maybe a lifter or two has a plugged oil port and is not pumping up properly. Do you see sludge under the oil cap?
Similarly, does this car get out on the highway very often, or is it a townie car?
- lext
- Year and Model: 1994 854
- Has thanked: 1 time
Thanks guys. I'm glad there's no adjustment to do, although it sounds like an oil pan drop is in order. I looked up the instructions and it sounds doable, although long period lying under the car may not be much funClemens wrote: 04 Apr 2018, 20:12 They use hydraulic lifters in 850ies. No need to adjust them. If your oil is dirty, you might get away with an oil change. Also, try to rev the engine beyond 4000 Rpm in gear, this usually helps to free stuck lifters in my 94
Clemens: I'm curious about your suggestion. How can you rev to 4000 rpm while in gear? Wouldn't that push your speed to way, way above the speed limit, or even the sane roadway limit? it's not like we have a desert nearby to drive freely at any speed we want to
94 850 non-turbo
2011 S40 T5
2011 S40 T5
- Been thanked: 4068 times
You can push it to 60in third gear in a standard or select a lower gear and lower speed in a slush box.
- June
- Has thanked: 523 times
- Been thanked: 261 times
I think Clemens is referring to sticking valves. My 98 V70 had the problem and the dealer told me to run the car in 2nd gear on the interstate holding 5000 rpm for 5 minutes with the ac off. The problem always went away for a half a year or so. Symptoms were always hard to start in the morning and rough idle. Of course the car was only a couple years old back then and under factory warranty still. I don't think I would do it to a neglected engine. Junelext wrote: 08 Apr 2018, 00:00Thanks guys. I'm glad there's no adjustment to do, although it sounds like an oil pan drop is in order. I looked up the instructions and it sounds doable, although long period lying under the car may not be much funClemens wrote: 04 Apr 2018, 20:12 They use hydraulic lifters in 850ies. No need to adjust them. If your oil is dirty, you might get away with an oil change. Also, try to rev the engine beyond 4000 Rpm in gear, this usually helps to free stuck lifters in my 94
Clemens: I'm curious about your suggestion. How can you rev to 4000 rpm while in gear? Wouldn't that push your speed to way, way above the speed limit, or even the sane roadway limit? it's not like we have a desert nearby to drive freely at any speed we want toUnless you're talking about one of those setup like at the smog check where the wheels just turn the roller but the car stand still.
My Volvo cars owned
1989 740 GLT ordered
1996 960 ordered
1998 V70 GT dealer stock car
2002 S80 T6 ordered totalled
1996 960 ordered
- oragex
- Year and Model: S60 2003
- Has thanked: 102 times
- Been thanked: 352 times
That sounds to me like the perfect example of a lifter ticking. If that's true, then by the loudness of the noise I'd say it's perhaps too late to do anything. It may still run like this but perhaps the valve is already damaged. I had a lifter like this, it got a little more loud then it finally burnt the valve while driving uphill. A new engine head was needed. Not sure if Seafoam will help as it needs to get into the lifter. Perhaps pour like 2 cans into the oil and run the engine for a few seconds every day for 1-2 weeks see if it helps then change the oil - the car should not be driven with such amount of Seafoam. But you may get other issues from this much Seafoam that may dislodge too much gunk from inside the engine.
A compression test may give an idea about the actual damage to the valve
- 1670 Views
Last post by polskamafia mjl
- 1747 Views
Last post by June
- 424 Views
Last post by ScottieB
- 14 Replies
- 1074 Views
Last post by hotdog067
- 16 Replies
- 2685 Views
Last post by kippster41493
