Daughter has a 98 S70, called me for a jump because it would not turn over. When i got there, the battery was fine, key turned everything on, but no connection to starter. Key could not be removed, and hazard lights would not turn off (still on 4 hours later)
Must be an electrical issue, anyone have any ideas?
98 S70 won't turn over
- Been thanked: 504 times
- Cannot start: could be the alarm system acting up.
- Key could not be removed. Please read this thread:
DIY: 1998 S70 GLT Ignition Tumbler FREE Fix!
viewtopic.php?f=1&t=67531
- FLXC90
- Year and Model: 98 V70 T5
- Has thanked: 16 times
- Been thanked: 45 times
Your alarm has been activated, try resetting with the key in the door lockdoshenjen wrote: 05 Apr 2018, 20:50 Daughter has a 98 S70, called me for a jump because it would not turn over. When i got there, the battery was fine, key turned everything on, but no connection to starter. Key could not be removed, and hazard lights would not turn off (still on 4 hours later)
Current Volvos:
- BEJinFbk
- Year and Model: '98 V70 R
- Has thanked: 94 times
- Been thanked: 146 times
Sounds like two separate problems.
+1 on the alarm being triggered.
If the key fob transmitter doesn’t reset it, then using
the key in the driver’s door to Unlock from that key
cylinder should also disarm the alarm.
If the key isn’t coming out of the ignition
switch, very common issues are the shifter
release button in the shifter handle or the shift
lock override button on the shifter console.
These buttons often gets sticky over time, and can get
stuck when pushed. I’d look at the shift lock override
button carefully. It’s not generally used, is prone to
getting gummed up by spilled drinks and there’s a
pretty good chance that someone pushed it when
the car wouldn’t start and it’s stuck down. That will
lock your key very firmly in the ignition...
Be sure that the shifter handle button is released all
the way out and the shift lock override button is all the
way up, and you should be able to remove the key.
- 18 Replies
- 8064 Views
- 2028 Views
Last post by matthew1
- 970 Views
Last post by Ozark Lee
- 1852 Views
Last post by 93Regina
- 1062 Views
Last post by Roger_850T
