My cooling fan will not come on. I replaced it and still won't come on.
Last week after I changed my oil, the fan started working but the temperature gauge stayed at 0!
After a while the temp gauge worked again, but the fan would not come on again!!!!!
HELP!!!!!!
Cooling fan 2000 S80
- oragex
- Year and Model: S60 2003
- Has thanked: 102 times
- Been thanked: 352 times
I'd look into the coolant temp sensor both the sensor and the wiring all along
jimmy57
- Has thanked: 5 times
- Been thanked: 322 times
Is it running hot? Is the outside temp above 70F with a/c running?
The fan will not be operated by the ECM until coolant temp reaches 225 or a little more and in cold weather it takes a long time sitting still running to reach that. If it isn't warm enough then the a/c high pressure will not be high enough for ECM to run fan for a/c needs.
- 1934 Views
Last post by redrayl
- 209 Views
Last post by UgDriveCar
- 3716 Views
Last post by s10lowrider1994
- 1741 Views
Last post by Ozark Lee
- 607 Views
Last post by subzerocarfanatic
