2000 V70 Stalling / Rough Start After Fueling
brunocerous
Year and Model: 1998 V70
Has thanked: 303 times
Been thanked: 43 times
Post by brunocerous »
Greetings!
I recently finished getting my newest Volvo fixer-upper to stage zero, finally replacing the fuel filter a couple of days ago, and had hoped it would end the stalling and/or rough start immediately after fueling up.
I'd had a P0445 code, which went away after replacing the fuel tank cap. But every time I put gas in it, the car doesn't want to start. It'll crank ok, then sputter and stall. I've tried letting the fuel pump run a couple of times by turning the key without cranking, but it made no difference. Eventually, I'll manage to give it enough gas to keep the RPMs up, and then it's fine.
I'd hoped it was a dirty fuel filter, but that doesn't appear to be the case. Could it be a bad fuel pump, or something else?
Any ideas would help!
1998 V70 T5, AT, project
2004 XC90 AWD (sold)
1999 V70 XC AWD, AT (RIP)
1998 S70 T5, AT (RIP)
wizechatmgr
Has thanked: 45 times
Been thanked: 128 times
Post by wizechatmgr »
Happen to check the fuel pressure at the injector rail? Could be a marginal (aka dying) pump.
Year and Model: Many Volvos
Been thanked: 76 times
Post by Ozark Lee »
I have had similar problems with all of my P80s if I filled it up beyond the point where the pump clicks off. I think what happens if you try to round it off to an even dollar amount is that the charcoal cannister gets flooded and it winds up sucking raw gas through the purge valve.
Once I figured out not to let it go beyond the pump shutting itself off I haven't had the problem since.
Has thanked: 1609 times
Been thanked: 4063 times
I can send my gauge down on the next RPI train..I’ll be down in the city next week, too
shiloh51933
Year and Model: 04 XC70/'98 V70XC
Has thanked: 28 times
Been thanked: 17 times
Post by shiloh51933 »
brunocerous wrote: 06 Apr 2018, 18:05 Greetings!
Your going to have to check out your Evap system, it's usually not the gas filler cap. Check all the hoses first, vent hose by filler cap, the purge valve...ect.
If U Wanna Play U Gotta Pay!!
Present Volvo Ownership:
2008 Volvo XC90 V8 Black
Previously Owned Volvo:
1996 Volvo 850 GLT Silver
1998 Volvo V70XC Dark Blue
2000 Volvo V70XC/SE Dark Blue
2004 Volvo XC90 T6 Gold
WhatAmIDoing
Has thanked: 104 times
Been thanked: 105 times
Post by WhatAmIDoing »
I have the same problem and have evap codes, but this only happens when buying discount gas. So I've always attributed these symptoms to buying low quality petrol. Never happens when I fill up at Shell, BP, Exxon, or Marathon (top tier).
brunocerous
Ozark Lee wrote: 06 Apr 2018, 19:06 I have had similar problems with all of my P80s if I filled it up beyond the point where the pump clicks off. I think what happens if you try to round it off to an even dollar amount is that the charcoal cannister gets flooded and it winds up sucking raw gas through the purge valve.
That's good to know. I have been fueling up to about 3/4 of a tank at most after springing a leak in my other ('98 V70) fuel filler neck gasket, though this one ('00 V70) doesn't have a leak. Plus, I don't like having the gas-station attendants (it's the only way to fuel up in New Jersey) spill fuel all over the side of the car.
abscate wrote: 06 Apr 2018, 19:11 I can send my gauge down on the next RPI train..I’ll be down in the city next week, too
That would be great. Maybe we can buy you a beer or two?
brunocerous
shiloh51933 wrote: 07 Apr 2018, 10:38 Your going to have to check out your Evap system, it's usually not the gas filler cap. Check all the hoses first, vent hose by filler cap, the purge valve...ect.
The code hasn't returned in a couple of months, thankfully. Keeping my fingers crossed that it stays that way.
WhatAmIDoing wrote: 09 Apr 2018, 11:12 I have the same problem and have evap codes, but this only happens when buying discount gas. So I've always attributed these symptoms to buying low quality petrol. Never happens when I fill up at Shell, BP, Exxon, or Marathon (top tier).
I hadn't thought of that. I'll try a different gas station next time. Thanks!
Just try not to mix Shell and Mobil gas, or oil
theWIFES_S70
Year and Model: 1998 S70 base
Has thanked: 61 times
Been thanked: 37 times
Post by theWIFES_S70 »
We need to make sure abscate swings by the weekend we pull the VR6 engine... :mrgreen:
Retired:
2015 Volvo S60, T5, 85K
