1998 V70XC Rear Propshaft "Hanger Bearing" Replacement?
- shiloh51933
- Has thanked: 28 times
- Been thanked: 17 times
My 1998 V70XC has a bad hanger bearing(center support bearing) on the rear propellar shaft. The rubber has totally seperated from the center of the bearing and there's no slip yoke on the u joint. It looks like the u-joints are welded to the shaft and that would make it difficult to replace the hanger bearing. Has anyone managed to replace the hanger bearing on the propshaft of a P80 V70XC? If so would you mind breaking it down?
If U Wanna Play U Gotta Pay!!
Present Volvo Ownership:
2008 Volvo XC90 V8 Black
Previously Owned Volvo:
1996 Volvo 850 GLT Silver
1998 Volvo V70XC Dark Blue
2000 Volvo V70XC/SE Dark Blue
2004 Volvo XC90 T6 Gold
- Year and Model: Many Volvos
- Been thanked: 76 times
The only way I know to do it is to send it off to a place like Colorado Drive shaft. The way it is made I think the only way to do it is to cut the shaft and weld it back together. I had the same thing happen about a month ago and I just removed it and it will stay that way.
It makes a heck of a racket when that happens. I thought about trying to limp it home and after driving about 20 feet I decided to call the tow truck.
- 850 LPT
- Has thanked: 335 times
- Been thanked: 247 times
Colorado Driveshaft is the way to go. I don't think anyone else has attempted to repair the center bearing.
Dirk
Dirk
58' Porsche Diesel Junior
13' Honda Odyssey
13' Honda Odyssey
- SuperHerman
- Been thanked: 207 times
I believe YouTube has a video on this. Watch it to see if it is applicable to your model. I know one can now source the parts on Ebay, at least for the newer models.
The design is pretty standard to all driveshafts, just a matter of getting parts.
- shiloh51933
On rwd hanger bearing replacement is fairly common, what a waste of a good propshaft they made it difficult for home tech.SuperHerman wrote: 07 Apr 2018, 23:17 I believe YouTube has a video on this. Watch it to see if it is applicable to your model. I know one can now source the parts on Ebay, at least for the newer models.
- shiloh51933
On this propshaft there's no slip joint, normally the U joint is connected to a slip joint rt b4 the hanger bearing. They welded the u-joints to the shaft, so you can't get hanger bearing off without cutting. If you cut it has to be re-welded and rebalanced ...I don't have the machine equipment for that.shiloh51933 wrote: 08 Apr 2018, 01:00On rwd hanger bearing replacement is fairly common, what a waste of a good propshaft they made it difficult for home tech.SuperHerman wrote: 07 Apr 2018, 23:17 I believe YouTube has a video on this. Watch it to see if it is applicable to your model. I know one can now source the parts on Ebay, at least for the newer models.
- SuperHerman
Look at this
The entire process is about four videos. Claims to be for your exact vehicle.
- SuperHerman
To add further - see this video for how to get bearing off:
Although for a different car if the bearing is seized on, just cut.
- shiloh51933
That's a video for a RWD Volvo 240 or 540, that's definitely not a V70XC propshaft.SuperHerman wrote: 08 Apr 2018, 12:42 To add further - see this video for how to get bearing off:
- shiloh51933
Bearing isn't seized, if you read some of my Post I stated that there's no slip joint to remove original hanger bearing and press a new hanger bearing on. I would have to cut the driveshaft all the way through to remove hanger bearing, then reweld the shaft back together then have a balancing machine to rebalance shaft after. I don't know about you but I don't own a machine shop. I'm not trying to be a wiseguy...I appreciate your effort.SuperHerman wrote: 08 Apr 2018, 12:42 To add further - see this video for how to get bearing off:
- 514 Views
Last post by VolvoOwl98
- 803 Views
- 550 Views
Last post by cn90
- 14 Replies
- 3166 Views
Last post by jvl
- 723 Views
Last post by SuperHerman
