Volvo 850 Passenger Airbag
Hello All, during a cleaning under the Dashboard of my 850 (removing old unused cables) I pulled out the 2 wires coming from the passenger airbag to the orange connector. on the one part of the connector (coming from the sensor module) I have the 2 wires with the color code Orange White and White. Those coming from the Airbag side are green and white. Does someone knows the correct way to pull the cables back
- Has thanked: 2200 times
If you look carefully at the connector are there numbers molded into the plastic for each connector pin?
