How to shift to neutral without key
jimmy57
- Been thanked: 322 times
Remove air cleaner box and detach the cable from lever on top of transmission. Two clicks and you are in Neutral. It will only move one way as Park position is an end point and it will not move any further in that direction.
- oragex
- Year and Model: S60 2003
- Has thanked: 102 times
- Been thanked: 352 times
To pop out the airbox just detach the hoses/cables around and pull it upwards with some force, it should snap free. Or use two long extensions and a 8 or 9mm socket and push downwards in the center of the three securing clips while pulling on the box. like here at 0:30jimmy57 wrote: 09 Apr 2018, 19:33 Remove air cleaner box and detach the cable from lever on top of transmission. Two clicks and you are in Neutral. It will only move one way as Park position is an end point and it will not move any further in that direction.
- 13 Replies
- 6461 Views
- 456 Views
- 1462 Views
Last post by chitownV
- 1327 Views
Last post by anothersullivan
- 4065 Views
Last post by lummert
