Injector seal confusion
2001 - 2007 V70
2001 - 2009 S60
2003 - 2007 S60 R
2004 - 2007 V70 R
Keensali1
Year and Model: 2003 V70
Post by Keensali1 »
Bought a set of injector o rings for my 2003 2.4 NA v70. The o rings are 2 different sizes. One seems larger and a bit thinner wall, the other is a smaller looking ring and thicker. Could someone let me know which one goes on the end that fits into the intake(not into the fuel rail)? If it helps, they are green injectors.
oragex
Year and Model: S60 2003
Has thanked: 102 times
Been thanked: 352 times
Post by oragex »
If I remember well the larger one goes on the top, smaller one near the nozzle. Good to make sure the environment is perfectly clean, including around the manifold. Smallest dirt particle near the seals and it will leak
Vaseline on the seals a must to reinstall (same for the FPS sensor)
Keensali1
Post by Keensali1 »
Thank you for taking the time to reply. Went with the thicker ones and no leaks.
