Extracting broken lug bolt?
s10lowrider1994
- Year and Model: 2000 v70
- Been thanked: 3 times
Anyone have a trick for extracting a broken lug bolt? The wheel lock snapped off flush with the front hub and I’m rolling around on 4 lugs.
sventastic
- Year and Model: 1996 854R
- Been thanked: 6 times
Drill it out with an extractor?
As a last resort, there's this... (but I'm not sure this will work on the chromed lug bolts)
1996 854R | M56H | 16T | 274k | BC, Canada
- Has thanked: 311 times
- Been thanked: 817 times
That should be an easy one to get out, if it's not rusted in. Hit it with a good penetrant, Liquid Wrench or PBblaster etc. No WD-40.
If you take off the wheel, there may be enough stud sticking out to just grab it with pliers and turn it out. Very easy. May not even need pliers. Or if the wheel isn;t enough, pull the brake disc. If all of the fails, be ready with the left handed drill bits and some oil, maybe a chisel to try tapping it loose, and/or a bolt extractor.
- theWIFES_S70
- Has thanked: 61 times
- Been thanked: 37 times
+1 Left-handed drill bits are a must-have for anyone that works on 20-year-old cars... I've used these from Irwin with a lot of success.erikv11 wrote: 15 Apr 2018, 09:36 If all of the fails, be ready with the left handed drill bits and some oil, maybe a chisel to try tapping it loose, and/or a bolt extractor.
https://www.amazon.com/dp/B0002NYBH8/re ... 08520&sr=1
Retired:
2015 Volvo S60, T5, 85K
- Been thanked: 504 times
- Depends where it is snapped off. If there is 2-3mm protrusion (after wheel is removed), then you can use a dremel to cut a slot, then use screwdriver to twist it off.
- I have a couple of lugs lying around, you can have them for free (just pay the shipping, which is < $10).
- Has thanked: 2196 times
- Been thanked: 1850 times
If you have no luck with that you may have to remove the caliper and rotor and you should have threads at the back that you can turn outwards or inwards to remove from the hub.
- Been thanked: 4063 times
Once the hub is off, do not pass go, go direct to machine shop with drill press , and watch them drill out in 5 seconds
Bring beer
Bring beer
- SuperHerman
- Been thanked: 207 times
In my experience I have drilled out the bolt with success. I center punch and start with a small drill bit making sure it is straight. From there I go big, almost size of actual hole with a left hand thread bit. At this point the heat and forces of drilling free up the broken bolt and it turns out rather easy. For those that don't work at this point I use an easy out and this works pretty easy. That has been my experience.
It wouldn't hurt to clean off the backside and hit with some solvent.
Hmmmm OP does say it broke off flush with the hub ... if that is truly the case then first pass may be the Dremel to slot whatever is sticking out that back of the hub, if there is anything.
s10lowrider1994
Borrowed an easy out from my dad, came right out with almost zero effort. Now to see if I can remove and correctly torque the rest of them without issues.
- 1467 Views
Last post by MDK
- 716 Views
Last post by misha
- 56 Views
Last post by 02S8029
- 60 Replies
- 7948 Views
Last post by ericmci
- 2432 Views
Last post by Kazthebassman
