Got an issue with my 2004 XC90 I was hoping the community might have some insight on.
About a week ago we were on a roadtrip, and I get a "Reduced Engine Performance" message. The car slowly started losing power. I pulled over, turned the car off and back on and it was fine.
Coming back from the trip, it happened one more time. And today when my wife was driving, it just cut off before even throwing up that warning.
I hooked it up to a scanner, and there are no code...either current, unverified, or stored. Very frustrating.
The only other symptom I'd notice was what felt like a slight engine skip in the mountains. It felt kind of like a cylinder misfire but my plugs are only six months old.
Any advice on what to check?
2004 T5 Losing Power, Shutting Off, No Codes
Joelfixesstuff
- Year and Model: 2004 XC90
- ggleavitt
- Year and Model: 06,08 XC90 V8
- Has thanked: 26 times
- Been thanked: 134 times
The ECM maybe had an issue with the engine and placed a component (or components) into a default value rather than dynamic, then produced the message you saw. Whatever condition caused it likely was cleared when you turned the car off and re-started.
If you get the car read by a Volvo tool (VIDA/DICE), pretty sure you'll find that something was reported with the number of occurrences, etc.
In the meantime, can vet the easy stuff if you have not (filters, hoses, etc.). PCV service ever been done on this car? Mileage?
Joelfixesstuff
Mileage is over 170 and I'm willing to bet it's never had a PCV service. I'm trying the easy stuff first and probably need to tackle that too. The manifold looks like it's a pain to pull off.
- oragex
- Year and Model: S60 2003
- Has thanked: 102 times
- Been thanked: 352 times
No code means to me the scanner is not one that can read on Volvo. I'm yet to see a Volvo without a single code. You'll need to hook up a Vida or a more expensive scanner.
Look first at the timing belt and what's around, including the pulleys on the serpentine belt. At 170K miles anything can happen. Even if the belt was replaced at 100K I'd check it, some owners may have used cheap parts on this.
- Been thanked: 504 times
- Agree with VIDA.
- Stalling without error codes: at 170K miles, suspect bad fuel pump or PEM, info in forum.
- I sent you a PM.
- I sent you a PM.
- 2121 Views
Last post by theWIFES_S70
- 1524 Views
Last post by IG-88A
- 1638 Views
- 948 Views
Last post by vorbosh
- 12 Replies
- 2537 Views
Last post by scottinalaska
