Hi all,
Had to replace the motor in my C70. I tested the motor for compression by turning it over using a starter connected to a manual transmission. All checked out. Reconnected the torque converter then the automatic transmission and installed it into the engine bay. After connecting the hoses and wires, I replaced fluids, added a battery and tried to start it.
Engine did not crank after several attempts.
Terminals of battery cables were warm.
None of the accessories are seized.
Turning over manually with crank pulley nut does not budge in either direction. Acts Seized?!
What am I missing?
Thank you for all suggestions.
Replaced motor, now acts likes its seized. Topic is solved
Ludermilch
- Year and Model: 98V70XC 98V70R 01C70
- Has thanked: 1 time
1998 V70XC
2001 C70
1998 V70R
2000 Subaru Outback VDC
Perception Fontana Tandem Kayak
2001 C70
1998 V70R
- Has thanked: 2199 times
Have you checked the timing belt is aligned and has not slipped so you are hitting valves?
- FLXC90
- Year and Model: 98 V70 T5
- Has thanked: 16 times
- Been thanked: 45 times
sounds like the torque converter is mis-positioned and jammed up against the transmission pump.
Current Volvos:
Ludermilch
This is what I fear and what is likely the problem. I did not test the motor after the automatic was connected. Thinking that I'll drop the subframe to one side to unbolt the transmission and try again.FLXC90 wrote: 19 Apr 2018, 00:21 sounds like the torque converter is mis-positioned and jammed up against the transmission pump.
1998 V70XC
2001 C70
1998 V70R
2001 C70
1998 V70R
Ludermilch
Thanks Neil, I don't believe this is the issue because there is no play in the crank at all. But if this turns out to be the solution I'll let you know.scot850 wrote: 18 Apr 2018, 19:21 Have you checked the timing belt is aligned and has not slipped so you are hitting valves?
1998 V70XC
2001 C70
1998 V70R
2001 C70
1998 V70R
Hopefully I am wrong! I wish you luck.
Ludermilch
After working the transmission away from the block, I turned the motor crank and all was well. I then slowly worked the transmission back into place while turning the motor crank till it mated together without issue. This solved the issue of my engine not cranking. Now on to finding the no start issue!!
1998 V70XC
2001 C70
1998 V70R
2001 C70
1998 V70R
- 2175 Views
- 700 Views
- 7992 Views
Last post by Sommerfeldt
- 17 Replies
- 4912 Views
Last post by dm635
- 1004 Views
Last post by June
