850 Timing Belt Replacement
banjoman
- Year and Model: 850, 1996
No doubt this is addressed on the site, but I could not locate it, so my apologies. My 1996 850 Wagon has 240k. The timing belt was replaced 7 years ago with 32,000 miles since. Should I replace it?
- Has thanked: 2866 times
- Been thanked: 1332 times
Yes. You're hitting the time limit, not the miles limit. It's 7 years/70k miles.
search.php?keywords=1996+850+timing+bel ... mit=Search
- misha
- Has thanked: 155 times
- Been thanked: 432 times
Time is relevant...but with only 32k on the belt i would leave it for 2-3 more years...if that is my car.
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
- Has thanked: 312 times
- Been thanked: 818 times
If you do decide to replace it keep in mind that this would be an unusual timing belt service: you would only change the belt, because you were concerned the rubber is deteriorating.
A "normal" timing belt service would always replace the accompanying roller pulleys, and sometimes also the hydraulic tenisoner and water pump, etc.
Your climate (GA) is warm but doesn't see very extreme temp swings, so like misha says I might let it go another year or two if it was me. Definitely inspect the belt though, for cracks.
- Has thanked: 1613 times
- Been thanked: 4078 times
I would also run that 2-3 more years, but I am a risk taker.
I ran my 99 to 137k, 14 years
I’m running my New Beetle belt 15 years
- 5517 Views
Last post by jimmy57
- 23 Replies
- 18342 Views
Last post by jonesg
- 20 Replies
- 17915 Views
Last post by Hurtfeelings
- 2374 Views
- 2536 Views
