1995 854T; 258,000 miles
Is it possible that a hole in the muffler could set a 4-4-3 code?
There is also a leak at the front pipe / rear pipe connection.
Front O2 sensor was changed at 216,000 miles.
Rear O2 sensor was changed at 250,000 miles.
I haven't checked O2 sensor voltage readings since the car is not on the road.
4-4-3 cat. efficiency. Hole in exhaust the cause?
- alschnertz
- Year and Model: 1995 854T
- Has thanked: 2 times
- Been thanked: 12 times
'84 Prelude
'06 MPV
'13 Ford Focus SE
'84 Prelude
'06 MPV
'13 Ford Focus SE
- RickHaleParker
- Been thanked: 977 times
Could be one of five things or a combination of two or more of the five.
1. Fuel pressure test
2. Compression test
3. Check for Intake Air leaks
4. Check for Exhaust Air leaks
5. TWC
28: 4-4-3 TWC efficiency. Signal faulty
DTC information 4-4-3
A2300687 Condition
The ECM continuously monitors the TWC's efficiency by comparing the signal from the rear HO2S with the signal from the front HO2S. When the TWC's efficiency deviates too much, the ECM sets DTC 4-4-3.
Substitute value
None.
Possible source
Fault symptoms
Can result in poorer performance.
2. Compression test
5. TWC
A2300687 Condition
Substitute value
None.
Possible source
- Uneven compression.
Air leakage in the intake system.
Air leakage in the exhaust system.
Incorrect fuel pressure.
Defective TWC.
Fault symptoms
Active
Past
Past
- alschnertz
Thanks.
I didn't think to check compression or fuel pressure because the car has always run well.
Haven't detected any misfires by the seat of my pants.
Your info looks thorough. Where did that come from?
'84 Prelude
'06 MPV
'13 Ford Focus SE
'84 Prelude
'06 MPV
'13 Ford Focus SE
- RickHaleParker
Copy and paste from Volvo VIDA 2014D.
Active
Past
Past
- 1147 Views
Last post by FLXC90
- 1167 Views
Last post by pgill
- 3218 Views
Last post by rspi
- 6404 Views
Last post by Pittsjock
- 19 Replies
- 3348 Views
Last post by mrbrian200
