locked out Topic is solved
kenzzz123
- Year and Model: 2002 s80
locked out
I have a 2002 s80 and have a dead battery and cant unlock the door to open the hood to jump it, key will not open the drivers door. And the remote won't either, Any ideas.
- June
- Has thanked: 523 times
- Been thanked: 261 times
Will the key work in the trunk? Above the license plate is a round black rubber plug with a keyhole behind it. June
My Volvo cars owned
1989 740 GLT ordered
1996 960 ordered
1998 V70 GT dealer stock car
2002 S80 T6 ordered totalled
1996 960 ordered
- June
If you have AAA they will come. If not to prevent damaging the car you will likely need a professional locksmith with the tools to go under the door glass belt molding to inside the car to pull the door handle inside the car. It is a strange long bent looking tool. Don't let the top of the door to be pried, that is incorrect and anyone trying that is not a professional. June
My Volvo cars owned
1996 960 ordered
1996 960 ordered
- oragex
- Year and Model: S60 2003
- Has thanked: 102 times
- Been thanked: 352 times
The key should unlock the trunk, it's mechanical not electrical, it would even trigger the alarm. Try again with the trunk, if it doesn't turn (same for the door), keep putting a little bit of pressure on the key while turning left-right and so on. Don't force, just a bit of pressure. At some moment it will give up all of a sudden and turn properly.
kenzzz123
I'll tryoragex wrote: ↑21 Apr 2018, 18:17The key should unlock the trunk, it's mechanical not electrical, it would even trigger the alarm. Try again with the trunk, if it doesn't turn (same for the door), keep putting a little bit of pressure on the key while turning left-right and so on. Don't force, just a bit of pressure. At some moment it will give up all of a sudden and turn properly.
- June
How did you get into the car? June
My Volvo cars owned
1996 960 ordered
1996 960 ordered
