So I have had a hard starting condition on the '99 V70 for a bit now. It strikes me as a typical bad engine coolant temperature sensor, but my sense with this car is that I've gone through quite a few of those sensors (Volvo only) and the problem eventually recurs. I have no check engine light and no stored codes. The car will start when cranked excessively with the gas pedal fully depressed. Any thoughts as to alternative causes before I throw another ECT at it?
I should add that fuel pressure at the rail appears good -- no numbers-- but forceful squirt from fuel rail, battery is in decent condition and coil packs and plugs don't have more than 20k miles on Bosch coil packs and Volvo three prong plugs.
Temp gauge on dash reads steady 3 o'clock.
B+ cable was replaced on this car. Starter does not seem bad and I believe all engine grounds are clean.
Massive vacuum leak possible?
'99 V70 Auto, Base -- Hard Start -- ECT or ?
- E Showell
- Year and Model: ‘07 S80 3.2
- Has thanked: 37 times
- Been thanked: 112 times
'95 855 auto (sold)
'86 245 manual (sold)
'05 V70 T5 M (totalled)
'06 V70 FWD Auto (totalled)
'02 Honda Insight CVT
‘06 Honda Insight CVT
'95 855 auto (sold)
- Has thanked: 2203 times
If replacing the ECT/IAT sensor fixes the issue and the car then starts ok, then it would appear to be the sensor, the question though is why are they failing so quickly. Being an NA it is less complex than the turbos in terms of leaks, but they usually throw codes.
Can't now recall if you have had the ETM replaced/rebuilt on this car?
- E Showell
ETM is Xemodex rebuild. Those Canadians do good work, eh?
'95 855 auto (sold)
'95 855 auto (sold)
- E Showell
Mechanic says starts fine now and he can't really see a problem. I guess it's fine 'til it isn't.
'95 855 auto (sold)
'95 855 auto (sold)
- WhatAmIDoing
- Has thanked: 104 times
- Been thanked: 105 times
Which really means "I can't find what's wrong, so I didn't fix anything, so the problems still there. Thank you for your money... I mean business."E Showell wrote: 24 Apr 2018, 09:10 Mechanic says starts fine now and he can't really see a problem. I guess it's fine 'til it isn't.
Knows enough to be dangerous
- E Showell
Didn't charge me a thing.
'95 855 auto (sold)
'95 855 auto (sold)
- Has thanked: 311 times
- Been thanked: 817 times
How about the ECT connector - give it a good physical and chemical cleaning, make sure the wires are in good shape.
- E Showell
Good call Erik. I asked my mechanic to check it. I have seen corruption in there in the past and didn't even think of that as a possible cause.
'95 855 auto (sold)
'95 855 auto (sold)
- Been thanked: 4068 times
Evan. Search on the part number plus resistance to check the resistance can vw spec, it’s in a thread in this forum.
I’ve also linked to this thread in my 1999 maintenance log, too
- 14 Replies
- 2785 Views
Last post by E Showell
- 2246 Views
- 17 Replies
- 4886 Views
- 2143 Views
Last post by SonicAdventure
- 206 Views
