parking brake cable - 2004 v70 - parts 9191484
- babybluebug
- Year and Model: 2004 v70
I am looking at overhauling the parking brake on a 2004 v70 including new e-brake shoes and the cables to the rear brakes. I was wondering if anyone has used ATE cables as opposed to volvo oem. Feedback appreciated!
- jonesg
- Year and Model: 2004 V70
- Has thanked: 73 times
- Been thanked: 532 times
Oem are discontinued by Volvo .babybluebug wrote: 27 Apr 2018, 12:50 I am looking at overhauling the parking brake on a 2004 v70 including new e-brake shoes and the cables to the rear brakes. I was wondering if anyone has used ATE cables as opposed to volvo oem. Feedback appreciated!
Try IPD.
Added part number to thread. 9191484
FCP shows that part indefinitely back ordered
It also shows compatibility with P2 V70s but only 2003-4 XC70 s ?
- jonesg
One of the mvs sponsors sells the cables. Eeuroparts, link is at the top of the page.
I got all 3 cables.
Ebrake still sucks.
I ordered the threaded barrel adjusters for the shoes. Waiting to install.
Supposedly the adjusters make all the difference.
I got all 3 cables.
Ebrake still sucks.
- babybluebug
Where did you order the adjusters from? I was just going to order the cable to the left and right rear brake (2 identical cables). My goal is to pass Mass state inspection. Never use the e-brake!
- jonesg
Yeh, I went thru that in MA last yr, so i moved to Maine, that'll teach em.!babybluebug wrote: 28 Apr 2018, 18:23 Where did you order the adjusters from? I was just going to order the cable to the left and right rear brake (2 identical cables). My goal is to pass Mass state inspection. Never use the e-brake!
Adjusters come as a complete kit with all the brake springs etc , IPD , I think it was $26 for both wheels plus $10 mail.
Mine is a 2004 v70.
From the invoice,
120935 - Parking Brake Hardware Kit - P2 S60 V70 XC70 XC90 S80
USD 26.95
- jonesg
Mine is a 2004 v70.
From the invoice,
USD 26.95
- oragex
- Year and Model: S60 2003
- Has thanked: 102 times
- Been thanked: 352 times
The adjusters help eliminate that 'delay' before the handbrake engages (the car still moves a few inches before the shoes can grab) when adjusted correctly through one of the rear drum holes. It also helps increase a little bit the 'bite' but nothing dramatic. What actually helps, is installing new cables.
But I found out that this doesn't last and it needs readjusted perhaps ever 6mths. It may also wear the shoes faster than without, because it basically keeps the shoes in a slight contact with the drum.
Btw grab the adjusters for free from the junk yard, every pre-2000 Volvo had them, such as S70, V70
- jonesg
Came across this video. He had to shorten the adjuster by cutting the end off.
Although IPD says it fits.
I'll take a look at mine later.
i never use my ebrake.
