Hi guys,
I am looking for instruction on how to replace the power steering high pressure hose (from the pump to the rack) and I don't seem to find it any where for my car: 2004 Volvo XC90 2.5T AWD
it started to leak and sprayed oil all over the engine compartment and alternator, belt..etc...do you recommend that I use some sort of degreaser spray to remove the oil?
Thanks
2004 XC90 2.5T Power Steering Pressure Hose Replacement 30665729
- FLXC90
- Year and Model: 98 V70 T5
- Has thanked: 16 times
- Been thanked: 45 times
At least a good sudsing of car wash soap using care around alternator and sensors. Not familiar with the 2.5, but when I pulled the subframe from my T6, there were a couple bolt-on clamps, and plastic clips. other than that, it's a matter of finding out how to snake the line in or out. You may need to disconnect a motor mount. Best of luck
Current Volvos:
- Been thanked: 504 times
- How many km/miles?
- Use only Volvo OEM hose b/c this is high-pressure hose.
- Below is the video for 2004 S60 Ps Pump (just the pump but you get the idea):
- At 120K miles, it is a bit early why that hose went south.
- Usually that high-pressure hose from the PS Pump lasts > 160K miles.
Added model and part number to title for search.
$200 part from FCP - ouch
- 2451 Views
Last post by Blacklab467
- 931 Views
Last post by VolvoChef
- 1665 Views
Last post by cn90
- 18 Replies
- 6553 Views
Last post by br0dy519
- 1074 Views
