s70 knock snsors How many and where located
harrelldodd
- Year and Model: 1999 s70
hello i have a 1999 s70 non turbo 2.4 im having knock sensor codes and have removed intake and can only find one sensor where every book ive looked in shows 2 sensors about 6 inches apart but i only see one and parts say 2 required soooo wheres the second one located? any help would be great
- Has thanked: 311 times
- Been thanked: 817 times
On a 99 there could be one knock sensor or two. Either way there is only one connector. I don't know which cars came with only one, but sounds like yours did.
For parts shopping: https://www.fcpeuro.com/products/volvo- ... 70-1275629
e.g. https://www.volvopartswebstore.com/prod ... 75629.html
- Has thanked: 2199 times
According to Vida, the S70 base (non-turbo) has the knock sensor option with only one sensor, listed as #10a in Erik's picture above.
Repair info does not specify the orientation of the sensor, but the picture shows it at 6 'o'clock, or with the cable exiting directly down, fed down behind the starter motor bracket and torque to 20Nm.
... your knock sensor codes probably aren’t caused by a bad knock Sensor, either
harrelldodd
Thanks for the info atleast now i dont feel like im crazy. ok abscate if not the sensor causing the code then any ideal what i need to look into? Thanks again for the help
- 1813 Views
Last post by precopster
- 22 Replies
- 1925 Views
- 2039 Views
Last post by cn90
- 1398 Views
Last post by E Showell
- 36 Replies
- 2293 Views
Last post by ericmci
