IPD sale Volvo Parts
Did you know? 🤔
2007 s80 v8 harsh shifting
Help, Advice, Owners' Discussion and DIY Tutorials on the current (third) generation Volvo V70 wagon and XC70 crossover, and second generation S80.
This is a forum for owners or prospective owners of the third generation V70, second generation S80, and its siblings built on the EUCD platform.
goldmandan
Year and Model: 1999 S 70, 2000 V70
Has thanked: 0
Been thanked: 0
Sweden
goldmandan
Post by goldmandan » Tue May 08, 2018 8:08 am
It's been a while since I've posted. Been enjoying our V70's without incidents. NOW, I purchased a 2007 s80 v8 which is an impressive car with it's awd and v8 set up. it really goes like a bat out of hell and is very comfortable BUT. the shift flares and bumping is very annoying. I have drained/filled transmission 2 times already and used transgo and lucas transmission additive to help prevent/stop hard shifting with no luck. I have contemplated to remove the transmission as the rear main is leaking and thus replacing the trans but I believe someone told me these transmissions (TF80SC) are pretty robust so I am wondering if I simply take the valve body out, clean it in solvent and blow it out with compressed air, replace solenoids with new ones will this fix my problem?
and, how easy is it to get to the solenoid cover and remove it?
Dan
oragex
Year and Model: S60 2003
Has thanked: 76 times
Been thanked: 139 times
Canada
oragex
Re: 2007 s80 v8 harsh shifting
Post by oragex » Tue May 08, 2018 9:42 am
I'd go the solenoids or valve body route - not sure which are needed so better search on forums although the information is rather scarce on these tf80. I've read some of them did fail so they are not that robust.
As for the solenoids, careful buying these from an Ebay seller, it's a jungle out there with several showing pictures of Rostra (for example) and shipping knockoffs. Better buy them from an official distributor
http://www.rostratransmission.com/repla ... sa-ssb.php
2003 2.4i S60 automatic 125k miles
DIY Volvo repairs videos https://www.youtube.com/playlist?list=P ... s0FSVSOT_c
goldmandan
Has thanked: 0
Been thanked: 0
Sweden
goldmandan
Post by goldmandan » Tue May 08, 2018 10:06 am
Thanks for the tip!! Wonder if rostra have a ebay store??
oragex
Canada
oragex
Post by oragex » Tue May 08, 2018 11:38 am
Don't think so, but someone may sell these on Ebay
jimmy57
Has thanked: 1 time
Been thanked: 127 times
jimmy57
Post by jimmy57 » Tue May 08, 2018 1:46 pm
Ramman Valve bodies, reamman.com, should be able to help.
Are you sure it is rear main seal? Power steering pump leaks are very common and run out through the bell housing drip hole.
goldmandan
Has thanked: 0
Been thanked: 0
Sweden
goldmandan
Post by goldmandan » Tue May 08, 2018 6:56 pm
It leaks between trans and engine and never had low power steering fluid so i dont think the pump is leaking i will check though
Thanks gor the remanned valvebodies link will chexk it out
goldmandan
Has thanked: 0
Been thanked: 0
Sweden
goldmandan
Post by goldmandan » Thu Jun 21, 2018 5:35 am
I got the valvebody rebuilt and now the shifting is perfect again! VERY happy!!!
I have another issue though, when I put the car in drive it seems to want to launch as soon as I let go the gas the car launches forward. strange! Could this be a bad motor mount??
oragex
Canada
oragex
Post by oragex » Mon Jun 25, 2018 10:37 am
Do you feel like there is an engagement delay when putting it in D? I had this after replacing the solenoids, I would move the lever in D then the transmission would engage with a 2 seconds delay plus it would kick with force (and a bang) upon engagement and the car would jump forward. Had to reset the adaptations with Vida then perform the garage shiftings. See here http://www.volvoxc.com/forums/showthrea ... alkthrough
Remember the adaptation works until the engine is switched off. Try also to launch the car several times with some acceleration from a standing point, to adjust the shifting for the first gears. The shiftings after this adaptation reset may be less good than before doing it, but the engagement in D should work fine again.
goldmandan
Has thanked: 0
Been thanked: 0
Sweden
goldmandan
Post by goldmandan » Mon Jun 25, 2018 2:22 pm
Smy scanner allows me to reset adaptatio s but i thought u can reset then tuen it off and it will relearn as u drive so u have to reset and drive at same time?
