For about a year now, my dash indicator lights for the blinkers both flash rapidly. I’m not sure what’s going on because all blinker bulbs are functioning. Both front and rear. Anyone have a suggestion?
Thanks in advance.
Paul
Blinker Indicator Dash Lights Flash Rapidly
- Has thanked: 2196 times
- Been thanked: 1850 times
Have you got the correct rated bulbs fitted into the car? Did you replace any around the time you started to get this issue?
Also it could be the flasher unit itself failing.
Should also add it could be a bad ground.
- 1190 Views
Last post by alschnertz
- 12 Replies
- 3384 Views
Last post by Jaguar xjs
- 2199 Views
Last post by VolvoHonda2014
- 825 Views
Last post by davidcschulte
- 11112 Views
Last post by dikidera
