Radiator expansion tank
Multiskilled
Year and Model: C70 t5 2000
Has thanked: 7 times
Post by Multiskilled »
Hi my radiator expansion tank has a hair line crack in it somewhere and a small amount of water is laying on the outside seem. I've seen a meyle one on eBay but it looks as though it doesn't come with the senser , is it possible to reuse my old one and are the meyle bottles any good
tryingbe
Year and Model: None
Has thanked: 1 time
Been thanked: 26 times
Post by tryingbe »
Get only the OEM one. Otherwise, the tank will not last long.
85 GLH, 367 whp
00 Insight, 72 mpg
WhatAmIDoing
Has thanked: 104 times
Been thanked: 105 times
Post by WhatAmIDoing »
OEM tank (we know the price sucks). I reused my sensor after confirming it worked. Just be careful removing and unplugging the sensor.
Has thanked: 2209 times
Been thanked: 1852 times
+1 sensor can be re-used, and as stated, careful with extraction of the old one.
Multiskilled
Ok thanks guys I thought you would all say that but worth a shot OEM it is
callahanoffroad
Year and Model: 1995 850
Has thanked: 16 times
Been thanked: 53 times
Post by callahanoffroad »
If it was a Honda Civic with a non pressurized expansion tank it'd be fine to go off brand. But the constant pressure can break cheap ones. I learned this on a land Rover...
Author, Chef, and Shade Tree Mechanic
1995 Volvo 850, Non-Turbo, VVIS, LH FI, Green, 215,000 miles. B5254FS engine. Herman. viewtopic.php?f=1&t=84393
1996 Volvo 850, died at 280,000
Founder of: CookingForChemo.Org
Read my Silly Comic Book at: therealpizzabros.com/
Multiskilled
Has anyone noticed a change in the colour of the water in the tank when it's cracked , mine has gone from red to a clear charcoal colour since I noticed the leak. Engine runs spot on ,temp gauge stays at quarter past, no sign of oil in water or water in oil do you think it's connected in some way
850 LPT
Has thanked: 335 times
Been thanked: 247 times
Post by 850 LPT »
Red?
Your coolant should look Volvo OEM blue. What kind of coolant do you have in there?
58' Porsche Diesel Junior
13' Honda Odyssey :oops:
Multiskilled
No idea it's what was in it when I got it
WhatAmIDoing
Should probably flush the cooling system and replace with Volvo coolant when you do the expansion tank. Good time to do all the hoses as well.
