Had a buddy's car for a month now. No cooling fan amount several other errors listed on Vida/Dice including no work DIM...several errors related to throttle pot and brake signal.
Since my experience with P2 coolings fans is the module fails in a way that caused 100% on 24/7 and not NO fan I went the ECM route due to several other errors and the DIM that appears to have 0% signal (although I know they tend to fail it's usually just a couple of things from my experience).
We have reflashed a ECM (didn't do it) and tested cooling fan with known good new (and used) cooling fan and nothing.
What are my next steps...can I test the signal wire in some way?
I'm beginning to think there is a major wiring concern sadly like his last P2. I have little to know skills for tracking down 101 wire issues, so I might be sending this one back.
Ideas?
Still no cooling fan...now what?
carboncow
- Year and Model: 2003 XC70 2018 S60
Shawn F.
2001 V70 T5
2003 XC70
1996 Vw Passat Tdi
1999 Porsche Boxster
2004 Chevy Suburban LT 5.3L
2013 & 2015 S60 T5
2008 Vw Touareg T2 V6
1989 Sea Ray 340 Sundander
2007 Sea Doo Challenger 180 SE
2001 V70 T5
2003 XC70
1996 Vw Passat Tdi
2013 & 2015 S60 T5
- Been thanked: 4064 times
Find the wiring diagram for his year make model, post up the cooling fan part, and we will have a go.
Yep, its never the ECU...
carboncow
Sadly, I went for the ECU/ECM because off all the side symptoms and a recommendation from another forum that it sounded like ECM!
Not having much luck on wiring diagrams for the cooling system. Does Vida-Dice have this info embedded there, somewhere?
2002 XC70
2002 XC70
Shawn F.
2001 V70 T5
2003 XC70
1996 Vw Passat Tdi
2013 & 2015 S60 T5
2001 V70 T5
2003 XC70
1996 Vw Passat Tdi
2013 & 2015 S60 T5
They probably think ‘Forums’ is a thing toocarboncow wrote: 13 May 2018, 10:16 Sadly, I went for the ECU/ECM because off all the side symptoms and a recommendation from another forum that it sounded like ECM!
2002 XC70
We have a legal agreement with Volvo to not host them here as moderators....but the community is free to do so. I think people search things like
Volvo wiring diagrams
Successfully
- jonesg
- Year and Model: 2004 V70
- Has thanked: 73 times
- Been thanked: 532 times
Cooling fan for the ecm box?carboncow wrote: 13 May 2018, 09:53 Had a buddy's car for a month now. No cooling fan amount several other errors listed on Vida/Dice including no work DIM...several errors related to throttle pot and brake signal.
Ideas?
You can just hotwire it to any switched power source .
Test fuse #8 in the engine compartment?
- MDK
- Year and Model: 2004 S60R
- Been thanked: 42 times
Thermostat sensor...it maybe that it's not sensing the temperature at top radiatior hose on engine... when the car was below about 32degrees ambient....it wouldn't start.... or maybe relay/ module ... the other thing is that when Volvo's have low voltage ..weak battery or weak alternators... they give you weird values... Id check that first
carboncow
[/quote]
So you are saying just to power it from any switch when the car is running for 24/7 fan?
Are we talking the purpose sense wire is the "on" trigger as the two heavy wires to the module are power...but not sure what makes them turn on.
EDIT: All fuses are 100%
Shawn F.
2001 V70 T5
2003 XC70
1996 Vw Passat Tdi
2013 & 2015 S60 T5
2001 V70 T5
2003 XC70
1996 Vw Passat Tdi
2013 & 2015 S60 T5
carboncow
Not overly helpful as the fan should turn on 100% any time the AC is engaged irregardless of water temp. One can (and I did) simulate a trigger for the thermostat sensor by simply disconnecting the clip.MDK wrote: 13 May 2018, 15:34 Thermostat sensor...it maybe that it's not sensing the temperature at top radiatior hose on engine... when the car was below about 32degrees ambient....it wouldn't start.... or maybe relay/ module ... the other thing is that when Volvo's have low voltage ..weak battery or weak alternators... they give you weird values... Id check that first
As far as weak power...such items were easily tested by including a charger on the circuit when doing all Vida/Dice tests to make sure voltage is over 13v+.
Shawn F.
2001 V70 T5
2003 XC70
1996 Vw Passat Tdi
2013 & 2015 S60 T5
2001 V70 T5
2003 XC70
1996 Vw Passat Tdi
2013 & 2015 S60 T5
carboncow
OK, so I came up with with document that is for 2003 (xc70/x90) and NOT 2002 but it's full of stuff that I'm not sure which part is helpful to the discussion. I couldn't find anything pertaining to "cooling circuit" and since I'm concerned the issue is something a little larger maybe the section on front control module is helpful??!?abscate wrote: 13 May 2018, 12:16They probably think ‘Forums’ is a thing toocarboncow wrote: 13 May 2018, 10:16 Sadly, I went for the ECU/ECM because off all the side symptoms and a recommendation from another forum that it sounded like ECM!
2002 XC70
Successfully
https://www.dropbox.com/s/2f8ak378jfka5 ... s.pdf?dl=0
Shawn F.
2001 V70 T5
2003 XC70
1996 Vw Passat Tdi
2013 & 2015 S60 T5
2001 V70 T5
2003 XC70
1996 Vw Passat Tdi
2013 & 2015 S60 T5
Brentscrazyptwo
- Year and Model: 2004 S60 2.5T
- Has thanked: 11 times
I am having the same problems with my 2004 S60 2.5T AWD stage 2 AWD. New factory fan installed, Volvo dealership could turn it on but does not turn on when air conditioner is turned on. It's my baby and I would appreciate some insight.
- 579 Views
Last post by Krons
- 11 Replies
- 2470 Views
Last post by mbaskette
- 1159 Views
Last post by precopster
- 551 Views
Last post by Volvonoob84
- 3604 Views
Last post by s10lowrider1994
