Changed fuel pump 1998 volvo v70xc.
Brianscott
- Year and Model: 1998 volvo v70xc
I changed my fuel pump and now theres no fuel at the rail. Before i changed it i would get some fuel at the rail and i couldnt hear the fuel pump come on at all. Now that i have changed it i hear the pump but there is jo fuel at the rail. Im lost at what to do. It would start sometimes with old pump but it gave out on me and i replaced it.
- Clemens
- Has thanked: 498 times
- Been thanked: 228 times
Did you reconnect the fuel lines properly? If you switch the two fuel lines you will not get pressure at the rail.
1996 855 R,
2010 V70 D5,
2010 V70 D5,
Brianscott
Yeah i put the lines on the correct ports. They arent long enough to not get them on the wrong ones on mine.
Brianscott
I used the aftermarket proparts pump assembly also. I spliced them as well
- Clemens
With Proparts you mean proparts sweden? The chinese super low quality brand? Alot of people had horrible experiences with their stuff. This sucks, especially on an awd.
1996 855 R,
2010 V70 D5,
2010 V70 D5,
- misha
- Has thanked: 155 times
- Been thanked: 432 times
With a ProParts fuel pump assemmbly,one of MVS members had car which burnt in a flame,because of a fuel leak which caused by a crack on assembly.Clemens wrote: 16 May 2018, 01:18 With Proparts you mean proparts sweden? The chinese super low quality brand? Alot of people had horrible experiences with their stuff. This sucks, especially on an awd.
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
Brianscott
Scary do you guys got any good brands suggestion or should i get oem
Brianscott
Maybe got a crap pump i think or they didnt put the pump correctly in the assembly
- misha
Stick to original used one from a junkyard...it is more reliable than new aftermarket from ProParts.
If you actually need a new one,stick with good known aftermarket brands like Hella,Delphi,Febi...etc.
Avoid a "never heard" brand for anything...even for vipers.
To avoid confusion....i'm talking about assembly.
For fuel pump...Walbro (if you have a luck to find original),Pierburg,Bosch(oem),Hella,Siemens or Meat & Doria(they have Bosch,Siemens or Pierburg inside the box).Whatever you get from those three brands in the box,they are oem quality.
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
- misha
You maybe can't go wrong on the outside of the housing,but check if you connected feed line correctly INSIDE the housing.Brianscott wrote: 15 May 2018, 15:07 Yeah i put the lines on the correct ports. They arent long enough to not get them on the wrong ones on mine.
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
- 39 Replies
- 2879 Views
Last post by VolvoOwl98
- 792 Views
Last post by leowill69
- 1308 Views
Last post by erikv11
- 3030 Views
Last post by Larry_Dean
- 42 Replies
- 12062 Views
Last post by Maestrours
