IPD sale Volvo Parts
That rattling is driving me nuts ...
Clemens
Has thanked: 47 times
Been thanked: 24 times
Austria
Post by Clemens » Wed May 16, 2018 3:12 pm
So my 96R is a pleasure on the freeway, but bumpy roads in the city are a pita. And since I have 2 more 850ies with very similar mileage (all around 190.000) I know it is alot worse in the R.
This probably comes from the 17 inch wheels and the sport suspension for 200.000 miles and and 22 years.
So what are the known culprits and how do I fix them?
I think I hear at least the following parts rattle:
Dashboard
Doorpanels (f+r)
Tailgate
Cargo cover (it works, but it rattles)
The suspension is in really good shape, so i know it is all just the interior.
Would new shocks improve the ride? They are not bouncy or leaking, but still the original ones.
Summer: 1996 855 R
Winter: 1994 855 T5M
Donor: 1995 854 10V
Has thanked: 5 times
Been thanked: 120 times
Canada
Re: That rattling is driving me nuts ...
Post by scot850 » Wed May 16, 2018 4:31 pm
At that age if the shocks are the originals you will notice a huge improvement with new ones. They tend to go hard and with the 17" wheels and little sidewall it amplifies all the rattles.
Having said that, here is what I usually find cause some of those issues you list:
1) Tailgate - 1) Inner panel has broken the mounts. Buy one of the repair kits (even Pro-Parts or Scantech work). Glue the metal
repair patches on for additional security of the repair using a glue that sticks plastic and metal.
2) Rear latch has worn out. There should be a plastic cover on the central pin the latch locks onto and usually it breaks
off allowing it to rattle. Try some electrical tape rapped around the pin in several layers and see if that helps. The latch
is not hugely expensive. and fairly easy for you to replace.
3) Check the rubber bump stops (one each side near the lower rear lights) have not broken off. Try greasing them a little
Lithium grease.
2) Door rattles : 1) Broken lower mount for the rear window guide. Not sure the 850 one is still available. The one for a V/S70 will
work, but you have to rivet it on unlike the original which used a small screw.
2) Check all the mountings are in place for the inner panel and not broken.
3) Check the door retainer straps are not broken or the mounting to the 'A' pillar.
4) If the door panels are 2 piece, check they have not separated. Not sure that is relevant to an 850, but just also
check they have not just come loose and tighten their mounting screws up.
3) Dashboard : Broken mounts. Big job, but I used plastic glue, a propane gas welder and metal straps to repair. Now stronger than
new. I think I wrote a repair on that for my 2000 V70 base.
4) Cargo cover: Only thing I can suggest is to check the runner end mounts. Chances are they are worm and rattle. Not aware of new
parts being available. Maybe try silicon grease or oil on them? Also check the end covers are not broken with age.
Skandix do a repair part as does a guy on Ebay in Belgium/Holland?
Hope that helps.
These users thanked the author scot850 for the post:
Clemens
2006 XC70
2015 Kia Sportage EX-L
2000 V70 SE NA - New project and test bed - Sold
misha
Has thanked: 17 times
Been thanked: 71 times
Serbia
Post by misha » Wed May 16, 2018 4:38 pm
If you ask me....shocks are good untill they start to leak.The same for rear nivomats.Even when they start to leak,you have time.Leak is just an indication that they are going bad.
Their condition does not depends on mileage.It depends of the roads condition the car had been driven on.
'97 850 2.5 20v /fully equipped/ Motronic 4.4 / polar white wagon
'91 Citroen XM 2.0 SI /fully equipped/mandarine red metallic
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
Clemens
Austria
Post by Clemens » Thu May 17, 2018 4:51 am
Neil, thank you for the detailed description.
I will try to fix the tailgate panel a third or fourth time, this time using some flecible glue or sthg. along with the brackets and clips. I think the upper bezel around the window is the main problem here.
The rear window guides were available 2 years ago. I have one in my toolbox. I never instslled it. The window works fine w/o it (surprisingly). I guess i will try to soundproof the doors and check for any rattling culprits inside the door.
I remember your dash fix. Very inspiring, as usual.
I might give new front shocks a though. I habe new rear nivos waiting for install, so i might just get front shocks as well.
Are the oem sachs front shocks different for lowered and standard suspension?
Summer: 1996 855 R
Donor: 1995 854 10V
callahanoffroad
Year and Model: 1995 850
Has thanked: 6 times
Been thanked: 8 times
United States of America
Post by callahanoffroad » Thu May 17, 2018 6:20 am
You need new shocks/struts all around. They do go bad over time. My 850 base had ORIGINAL shocks and struts from the factory. They weren't blown and rattling nor leaking but they were definitely tired and worn. New on all 4 corners made all the difference.
Is your wagon door rattling, squeeking or bumping?
My wagon never ceased to bump over bumps in the road. Nearly drove me mad. Man I miss that car...
These users thanked the author callahanoffroad for the post:
Clemens
1995 Volvo 850, Non-Turbo, VVIS, LH FI, Green, 190,000 miles. Herman. viewtopic.php?f=1&t=84393
Clemens
Austria
Post by Clemens » Thu May 17, 2018 3:32 pm
The wagon door is squaking and rattling. The bumpiness went away after setting up the gap of the lock mechanism correctly. The lower part of the tailgate cover sits quite firmly, but I believe it is atill rattling and squeaking. Gotta add some gooey glue to all the contact areas between plastic and door/glass i believe.
I just checked the doors and the dashboard. They seem pretty solid. I think they are good.
Maybe it's time to install new shocks and toss out the front cross brace...
Summer: 1996 855 R
Donor: 1995 854 10V
amblerman
Year and Model: 1999 s70
Been thanked: 10 times
Post by amblerman » Thu May 17, 2018 4:44 pm
If you want to see a different option for dash mount repairs, take a look at what I did back in July of 2017.
viewtopic.php?f=1&t=81991&p=444318#p444318
My dash is still quite and quite solid.
My method does require a couple of days to let the the ABS cement to fully set and allow multiple layers to build up. Not difficult, just requires some time. Like if you don't need your car for a long weekend. :-)
BTW. There are a lot of things I like about my volvo. The way they designed the dashboard mounting points is not one of them. I feel as if they are doomed to fail. It's the only car I've ever had fail in this way. On the upside, it was completely fixable.
Andy
These users thanked the author amblerman for the post:
Clemens
Kara503
Year and Model: 1996 850 Plat R-Swap
Has thanked: 11 times
Post by Kara503 » Fri May 18, 2018 12:46 pm
I have most of the rattles you guys have been talking about, but also another nobody has mentioned- my second row seats squeak and rattle all the time. I believe the noise is coming from the latch that you disengage so you can fold them down. The seats freely move just a bit when in the up and latched position so they rattle back and forth. Might check that too.
I wrapped the posts that the latches attach to in electrical tape and it solved the problem, but that only works until you fold the seats down 2 or 3 times and it breaks the tape.
These users thanked the author Kara503 for the post:
Clemens
Clemens
Austria
Post by Clemens » Fri May 18, 2018 4:20 pm
Andy, thanks for the link. This helps alot. I indeed found one broken tab on the dash today.
As for the second row seats: have you tried duct tape? It should withstand the abuse better.
Summer: 1996 855 R
Donor: 1995 854 10V
Clemens
Austria
Post by Clemens » Thu Jun 14, 2018 4:25 am
Reporting back on this:
Meanwhile I came closer to silence:
- I installed my brandnew sport nivos and springs in the rear
- I removed my kid´s MCs from the glovebox (for those born later than our cars: Music Cassettes are ancient music storage devices that rattle like hell over any road imperfection) and put them in the seat pockets
- Upon closer inspection, the doors weren´t rattling, just stuff in the door pockets which I simply removed.
- I removed the upper dash pad and fixed a few cracks and the odometer gear and supported the dash itself with 2 additional drywall screws.
- I am about to order H&R front springs which should only be a tad lower than the original R springs but with a progressive rate which in theory should be a bit softer over tiny bumps. I willl also get new struts (probably Sachs oil filled standard struts) and new strut seats and so on.
This leaves me with a quite improved ride by now, with only the tailgate left as a source of noise. I will tackle that after my vacation!
Thanks for all your contributions
Summer: 1996 855 R
Donor: 1995 854 10V
Who is online
Users browsing this forum: Chuck W, ecbsykes, GlennG2759, Google Adsense [Bot], misha, tysauce1986 and 85 guests
