Small holes on s80 cylinder head
nathanepstein
- Year and Model: 2000 s80 t6
- SuperHerman
- Been thanked: 207 times
I don't recall as working on this head is several years ago. Looking at the photo I would assume they are oil passages. Look for a clean one, take some carb or similar cleaner and insert the plastic pipe into it and spray. See where it comes out and what comes out. What does the other side of the valve cover look out - these may be oil passages to lube the upper cams. Do the same on the corresponding side of the valve cover - if they are oil passages you need those clean. You can spray and use a small wire, copper, and clean them out. If you have a carb wire set, use that. While spraying, be careful of back spray and your eyes.
They could be some exhaust emission passages - just don't remember. They still need to be cleaned out either way.
Head looks good though.
jimmy57
- Has thanked: 5 times
- Been thanked: 322 times
They are drilled to intersect he lifter bores. For either hydraulic or the solid buckets. If you look at top of head you will see the "ditch" cast into head to carry oil along the full length of head on intake and exhaust sides.
thebull
- Year and Model: XC90 R-Design 2009
Oil passages delivering oil to the tappets. Check your cover and you will see how they are matching with the oil canals there. Make sure that you spray compressed air in each hole to ensure there is no obstruction to the oil flow. The are very important holes.
Your pic is bringing some memories back
cheers
Flying on 2009 XC90 R-design 3.2L AWD and 2006 XC90 2.5T AWD. Volvo owner forever.
- 356 Views
Last post by nthnnxn
- 1692 Views
Last post by rspi
- 2151 Views
Last post by precopster
- 1917 Views
Last post by ta79pr
- 13 Replies
- 8402 Views
Last post by lifeofgold
