IPD sale XeMODeX - Experts in Volvo Electronics
Did you know? 🤔
Logged in users can get email notification of topic replies Log in or register (free).
Amazon Link Buy your stuff using this and it helps MVS!
97 850 NA - Regular soft knocks/clicks -- repeated pattern of movement
xHeart
Year and Model: 1997 854 NA
Has thanked: 17 times
Been thanked: 27 times
United States of America
xHeart
Re: 97 850 NA - Regular soft knocks/clicks -- repeated pattern of movement
Post by xHeart » Tue May 14, 2019 2:05 pm
The intermediate arm was replaced, BUT was it installed correctly?
In preparation for summer and air conditioning, the REC switch for air recirculation is causing strange behavior. Key in POS II, REC ON (light ON) it has motor rotation and thump of vent door -- it cycles. REC OFF (light OFF) it clicks and thumps repeatedly.
The climate control is without ECC.
Install orientation is same as in this diagram #18:
Golden Retriever | 2014D VIDA DiCE | 2013A XC90 +140mi/225km | 2001 V70XC 1st Owner +190mi/ +305km | 1997 Volvo 850 NA 1st Owner +180mi/ +289km
Past: German Shepherd | 1989 Volvo 740 GL | 1979 Volvo 240
xHeart
xHeart
Post by xHeart » Thu May 16, 2019 11:25 am
Removing the six 25T screwed and pulling out the glovebox gives access.
I couldn't understand the motor's rotation for the REC switch ON/OFF -- it cycles with ON, and clicks with OFF. So, I decided to take off intermediate lever/arm from the motor. It disengaged the vent door opening/closing function. Left the REC switch is ON (light ON) to avoid the clicks of OFF position.
Is the vent closed when REC is ON (light ON) -- #6 flap in closed position -- recirculating cabin air? How does cabin air flows with REC switch at ON/OFF?
xHeart
xHeart
Post by xHeart » Tue Jun 25, 2019 9:12 am
Removed the cowl to check the flap position under the cabin filter assembly. The blower fan being visible and flap down means the ambient air is entering the cabin -- which is preferred/standard.
I'll leave the arm/lever disconnected to keep the outside air flow in to the cabin for now, but later look for ways to repair before the winter weather. ALSO keeping RECIRC switch to ON position so motor can stay quiet -- motor clicks when switch is OFF.
Why would motor turn and make clicking noise if the RECIRC switch is at OFF position?
Year and Model: 99T5 ,99S70,2005V70
Has thanked: 212 times
Been thanked: 690 times
Trinidad & Tobago
Post by abscate » Tue Jun 25, 2019 9:35 am
OFF doesn't mean motor off, it means it is trying to return the flap to the ambient air position. I think the motor is encoded on both ECC (Electronic climate control) and MCC (Manual climate control) so if the encoder doesn't report the right position it keeps trying to position it.
Does that make sense ?
1999-V70-T5M56 2005-V70-M56 1999-S70 VW T4 BMW
xHeart
xHeart
Post by xHeart » Tue Jun 25, 2019 10:24 am
It does!
I'm able to pull the link arm #21 to move the flap to recirc position, releasing link arm returns flap to ambient air position.
It would then make sense to connect link arm #21 to lever #18 AND then hang it at motor with switch at OFF and engine OFF. BUT the square male connector at motor doesn't sync with female connector at lever -- where to reconcile.
Trinidad & Tobago
Post by abscate » Tue Jun 25, 2019 3:17 pm
You have to drive it to the OFF position with engine on and make sure the motor reaches the recirc damper is OPEN
xHeart
xHeart
Post by xHeart » Wed Aug 07, 2019 10:59 am
Seeking clarity.
With cowl removed, and cabin filter pulled, I can see the fan motor -- that is fresh air entering the cabin -- right?.
recirc damper is OPEN would mean damper up and closed, I should not see the fan from the cowl/filter assembly, yes?
