Moisture in distributor cap
Scratchy2000
Year and Model: v70 xc awd 1998
Post by Scratchy2000 »
I have a Volvo v70 1998 wagon and I believe that I have moisture in the distributor cap as the car cranks but won't spark in and shortly after rain. I really don't want to spend much money as the car is on its last legs. Can I put heat resistant tape around the seals are does anyone know of another quick fix? Thanks in advance.
FLXC90
Year and Model: 98 V70 T5
Has thanked: 16 times
Been thanked: 45 times
Post by FLXC90 »
pull the cap and wipe it out. maybe smear some wax on the cap flange. Do a glove test,
Current Volvos:
Has thanked: 1610 times
Been thanked: 4065 times
A Nitrile glove has four fingers and a thumb - so if you cut one more hole for the coil wire you have a perfect Volvo waterproofing sleeve.
bmdubya1198
Year and Model: 2K V70R M56
Has thanked: 316 times
Been thanked: 531 times
Post by bmdubya1198 »
Try to see where there is water getting into that area. Being that there's no seal on the cap, you probably won't have to worry about changing any of that.
Might be worth pulling it anyway to check for oil, your cam seal may be leaking.
+1 to smearing grease on the cap to head flange.
