Floats back up from time to time and may not be complete, came across this copy in VIDA (MY2005) while looking for something else-
SAE/ISO DTCs- Volvo DII DTCs- Diagnostic trouble code (DTC) designation- Fault type-
P0016 ECM-670C Camshaft position, inlet High
P0016 ECM-670D Camshaft position, inlet Low
P0017 ECM-671C Camshaft position, exhaust High
P0017 ECM-671D Camshaft position, exhaust Low
P0026 ECM-6110 Camshaft control, inlet Slow
P0026 ECM-611B Camshaft control, inlet Faulty
P0027 ECM-6140 Camshaft control exhaust Slow
P0027 ECM-614B Camshaft control exhaust Faulty
P0030 ECM-244B Front heated oxygen sensor, bank 1 heating Signal missing
P0031 ECM-244D Front heated oxygen sensor, bank 1 heating Signal too low
P0032 ECM-244C Front heated oxygen sensor, bank 1 heating Signal too high
P0036 ECM-223B Rear heated oxygen sensor, bank 1 Signal missing
P0037 ECM-223D Rear heated oxygen sensor, bank 1 Signal too low
P0038 ECM-223C Rear heated oxygen sensor, bank 1 Signal too high
P0040 ECM-24A0 Front heated oxygen sensors mixed up Faulty signal
P0041 ECM-2240 Rear heated oxygen sensors, mixed up Faulty signal
P0050 ECM-254B Front heated oxygen sensor, bank 2 heating Signal missing
P0051 ECM-254D Front heated oxygen sensor, bank 2 heating Signal too low
P0052 ECM-254C Front heated oxygen sensor, bank 2 heating Signal too high
P0053 ECM-2400 Front heated oxygen sensor, bank 1 heating Faulty signal
P0053 ECM-240B Front heated oxygen sensor, bank 1 heating Signal missing
P0053 ECM-240C Front heated oxygen sensor, bank 1 heating Signal too high
P0053 ECM-240D Front heated oxygen sensor, bank 1 heating Signal too low
P0056 ECM-233B Rear heated oxygen sensor, bank 2 Signal missing
P0057 ECM-233D Rear heated oxygen sensor, bank 2 Signal too low
P0058 ECM-233C Rear heated oxygen sensor, bank 2 Signal too high
P0059 ECM-2500 Front heated oxygen sensor, bank 2 heating Faulty signal
P0059 ECM-250B Front heated oxygen sensor, bank 2 heating Signal missing
P0059 ECM-250C Front heated oxygen sensor, bank 2 heating Signal too high
P0059 ECM-250D Front heated oxygen sensor, bank 2 heating Signal too low
P0071 ECM-1410 Ambient temperature sensor Faulty signal
P0071 ECM-141B Ambient temperature sensor Signal missing
P0072 ECM-140D Ambient temperature sensor Signal too low
P0073 ECM-140C Ambient temperature sensor Signal too high
P0075 ECM-612B Intake camshaft reset valve Signal missing
P0076 ECM-612D Intake camshaft reset valve Signal too low
P0077 ECM-612C Intake camshaft reset valve Signal too high
P0078 ECM-616B Exhaust camshaft reset valve Signal missing
P0079 ECM-616D Exhaust camshaft reset valve Signal too low
P0080 ECM-616C Exhaust camshaft reset valve Signal too high
P0087 ECM-290D Fuel pressure Signal too low
P0088 ECM-290C Fuel pressure Signal too high
P0089 ECM-2900 Fuel pressure Faulty signal
P0090 ECM-290B Fuel pressure Signal missing
P0100 ECM-120C Air mass Signal too high
P0100 ECM-120D Air mass Signal too low
P0101 ECM-1210 Mass air flow sensor Flow too high
P0101 ECM-121B Mass air flow sensor Flow too low
P0102 ECM-121D Mass air flow sensor Signal too low
P0103 ECM-121C Mass air flow sensor Signal too high
P0110 ECM-132D Intake air temperature (IAT) sensor inlet Signal too low
P0111 ECM-1320 Intake air temperature (IAT) sensor inlet Faulty signal
P0111 ECM-132C Intake air temperature (IAT) sensor inlet Signal too high
P0112 ECM-131C Intake air temperature (IAT) sensor inlet Signal too high
P0113 ECM-131D Intake air temperature (IAT) sensor inlet Signal too low
P0117 ECM-273C Engine coolant temperature (ECT) sensor Signal too high
P0118 ECM-273D Engine coolant temperature (ECT) sensor Signal too low
P0121 ECM-9210 Electronic throttle unit, potentiometer 1 Faulty signal
P0122 ECM-921D Electronic throttle unit, potentiometer 1 Signal too low
P0123 ECM-921C Electronic throttle unit, potentiometer 1 Signal too high
P0125 ECM-270B Engine coolant temperature (ECT) sensor Signal missing
P0128 ECM-2B00 Thermostat Faulty signal
P0131 ECM-248D Front heated oxygen sensor, bank 1 Signal too low
P0132 ECM-248C Front heated oxygen sensor, bank 1 Signal too high
P0133 ECM-242D Front heated oxygen sensor, bank 1 Signal missing
P0136 ECM-222B Rear heated oxygen sensor, bank 1 Signal missing
P0137 ECM-222D Rear heated oxygen sensor, bank 1 Signal too low
P0138 ECM-222C Rear heated oxygen sensor, bank 1 Signal too high
P0140 ECM-221B Rear heated oxygen sensor aging, bank 1 Signal missing
P0140 ECM-221C Rear heated oxygen sensor aging, bank 1 Signal too high
P0140 ECM-221D Rear heated oxygen sensor aging, bank 1 Signal too low
P0141 ECM-2200 Rear heated oxygen sensor bank 1, heating Faulty signal
P0151 ECM-258D Front heated oxygen sensor, bank 2 Signal too low
P0152 ECM-258C Front heated oxygen sensor, bank 2 Signal too high
P0153 ECM-252D Front heated oxygen sensor, bank 2 Signal missing
P0156 ECM-232B Rear heated oxygen sensor, bank 2 Signal missing
P0157 ECM-232D Rear heated oxygen sensor, bank 2 Signal too low
P0158 ECM-232C Rear heated oxygen sensor, bank 2 Signal too high
P0160 ECM-231B Rear heated oxygen sensor aging, bank 2 Signal missing
P0160 ECM-231C Rear heated oxygen sensor aging, bank 2 Signal too high
P0160 ECM-231D Rear heated oxygen sensor aging, bank 2 Signal too low
P0161 ECM-2300 Rear heated oxygen sensor bank 2, heating Faulty signal
P0182 ECM-2A0D Fuel temperature sensor Signal too low
P0183 ECM-2A0C Fuel temperature sensor Signal too high
P0190 ECM-280B Fuel pressure sensor Signal too high
P0191 ECM-2800 Fuel pressure sensor Signal too low
P0192 ECM-280D Fuel pressure sensor Signal too low
P0193 ECM-280C Fuel pressure sensor Signal too high
P0197 ECM-540D Oil quality, level and temperature sensor Signal too low
P0198 ECM-540C Oil quality, level and temperature sensor Signal too high
P0199 ECM-540B Oil quality, level and temperature sensor Faulty signal
P0201 ECM-2C0B Injector cyl 1 Signal missing
P0202 ECM-2C1B Injector cyl 2 Signal missing
P0203 ECM-2C2B Injector cyl 3 Signal missing
P0204 ECM-2C3B Injector cyl 4 Signal missing
P0205 ECM-2C4B Injector cyl 5 Signal missing
P0206 ECM-2C5B Injector cyl 6 Signal missing
P0221 ECM-9220 Electronic throttle unit, potentiometer 2 Faulty signal
P0222 ECM-922D Electronic throttle unit, potentiometer 2 Signal too low
P0223 ECM-922C Electronic throttle unit, potentiometer 2 Signal too high
P0234 ECM-601C Turbo control defective boost pressure Signal too high
P0237 ECM-125D Charge pressure sensor Signal too low
P0238 ECM-125C Charge pressure sensor Signal too low
P0240 ECM-1260 Charge pressure sensor Faulty signal
P0240 ECM-126B Charge pressure sensor Signal missing
P0240 ECM-126C Charge pressure sensor Signal too high
P0240 ECM-126D Charge pressure sensor Signal too low
P0243 ECM-600B Turbocharger (TC) control valve Signal missing
P0245 ECM-600D Turbocharger (TC) control valve Signal too low
P0246 ECM-600C Turbocharger (TC) control valve Signal too high
P0261 ECM-2C0D Injector cyl 1 Signal too low
P0262 ECM-2C0C Injector cyl 1 Signal too high
P0264 ECM-2C1D Injector cyl 2 Signal too low
P0265 ECM-2C1C Injector cyl 2 Signal too high
P0267 ECM-2C2D Injector cyl 3 Signal too low
P0268 ECM-2C2C Injector cyl 3 Signal too high
P0270 ECM-2C3D Injector cyl 4 Signal too low
P0271 ECM-2C3C Injector cyl 4 Signal too high
P0273 ECM-2C4D Injector cyl 5 Signal too low
P0274 ECM-2C4C Injector cyl 5 Signal too high
P0276 ECM-2C5D Injector cyl 6 Signal too low
P0277 ECM-2C5C Injector cyl 6 Signal too high
P0299 ECM-602D Turbo control defective flow Signal too low
P0300 ECM-3100 Misfire, at least one cylinder Start-up
P0300 ECM-310C Misfire, at least one cylinder Cat conv. damage
P0300 ECM-310D Misfire, at least one cylinder Emissions impact
P0301 ECM-3210 Misfire cylinder 1, start-up Start-up
P0301 ECM-321C Misfire cylinder 1, Cat conv. damage Cat conv. damage
P0301 ECM-321D Misfire cylinder 1, emissions impact Emissions impact
P0302 ECM-3220 Misfire cylinder 2, start-up Start-up
P0302 ECM-322C Misfire cylinder 2, Cat conv. damage Cat conv. damage
P0302 ECM-322D Misfire cylinder 2, emissions impact Emissions impact
P0303 ECM-3230 Misfire cylinder 3, start-up Start-up
P0303 ECM-323C Misfire cylinder 3, Cat conv. damage Cat conv. damage
P0303 ECM-323D Misfire cylinder 3, emissions impact Emissions impact
P0304 ECM-3240 Misfire cylinder 4, start-up Start-up
P0304 ECM-324C Misfire cylinder 4, Cat conv. damage Cat conv. damage
P0304 ECM-324D Misfire cylinder 4, emissions impact Emissions impact
P0305 ECM-3250 Misfire cylinder 5, start-up Start-up
P0305 ECM-325C Misfire cylinder 5, Cat conv. damage Cat conv. damage
P0305 ECM-325D Misfire cylinder 5, emissions impact Emissions impact
P0306 ECM-3260 Misfire cylinder 6, start-up Start-up
P0306 ECM-326C Misfire cylinder 6, Cat conv. damage Cat conv. damage
P0306 ECM-326D Misfire cylinder 6, emissions impact Emissions impact
P0324 ECM-3000 Engine control module (ECM), Internal fault Faulty signal
P0324 ECM-3010 Engine control module (ECM), Internal fault Faulty signal
P0324 ECM-3020 Engine control module (ECM), Internal fault Faulty signal
P0327 ECM-303D Knock sensor front Signal too low
P0328 ECM-303C Knock sensor front Signal too high
P0332 ECM-304D Knock sensor rear Signal too low
P0333 ECM-304C Knock sensor rear Signal too high
P0335 ECM-500B Engine speed (RPM) sensor signal Signal missing
P0336 ECM-5000 Engine speed (RPM) sensor signal Faulty signal
P0337 ECM-500D Engine speed (RPM) sensor signal Signal too low
P0338 ECM-500C Engine speed (RPM) sensor signal Signal too high
P0340 ECM-340B Camshaft position (CMP) sensor, intake Signal missing
P0342 ECM-340D Camshaft position (CMP) sensor, intake Signal too low
P0343 ECM-340C Camshaft position (CMP) sensor, intake Signal too high
P0344 ECM-3400 Camshaft position (CMP) sensor, intake Faulty signal
P0345 ECM-341B Camshaft position (CMP) sensor, exhaust Signal missing
P0347 ECM-341D Camshaft position (CMP) sensor, exhaust Signal too low
P0348 ECM-341C Camshaft position (CMP) sensor, exhaust Signal too high
P0349 ECM-3410 Camshaft position (CMP) sensor, exhaust Faulty signal
P0351 ECM-360B Ignition coil cyl 1 Signal missing
P0352 ECM-361B Ignition coil cyl 2 Signal missing
P0353 ECM-362B Ignition coil cyl 3 Signal missing
P0354 ECM-363B Ignition coil cyl 4 Signal missing
P0355 ECM-364B Ignition coil cyl 5 Signal missing
P0356 ECM-365B Ignition coil cyl 6 Signal missing
P0420 ECM-400C Catalytic converter efficiency, bank 1 Signal too high
P0430 ECM-401C Catalytic converter efficiency, bank 2 Signal too high
P0442 ECM-439C Tank system, leakage Major leak
P0443 ECM-421B Evaporative emission system (EVAP) valve Signal missing
P0444 ECM-421C Evaporative emission system (EVAP) valve Signal too high
P0445 ECM-421D Evaporative emission system (EVAP) valve Signal too low
P0456 ECM-434C Tank system, leakage Minor leak
P0457 ECM-430C Tank system, leakage Fuel tank cap missing
P0457 ECM-4380 Tank cap ` Missing
P0460 ECM-440C Fuel level sensor Signal too high
P0461 ECM-4400 Fuel level sensor Faulty signal
P0464 ECM-440B Fuel level sensor Signal missing
P0480 ECM-650B Engine cooling fan (FC) Signal missing
P0483 ECM-6200 Engine cooling fan (FC) control module Faulty signal
P0484 ECM-620C Engine cooling fan (FC) control module Signal too high
P0485 ECM-620D Engine cooling fan (FC) control module Signal too low
P0496 ECM-420C EVAP-system Signal too high
P0497 ECM-420D EVAP-system Signal too high
P0500 ECM-530C Speed signal Signal too high
P0501 ECM-5300 Speed signal Faulty signal
P0502 ECM-530D Speed signal Signal too low
P0503 ECM-A12B Speed signal Signal missing
P0503 ECM-A12C Speed signal Signal too high
P0503 ECM-530B Speed signal Signal missing
P0506 ECM-951D Engine control module (ECM), idle control Signal too low
P0507 ECM-951C Engine control module (ECM), idle control Signal too high
P0530 ECM-520B A/C pressure sensor Signal missing
P0531 ECM-5200 A/C pressure sensor Faulty signal
P0532 ECM-520D A/C pressure sensor Signal too low
P0533 ECM-520C A/C pressure sensor Signal too high
P0560 ECM-8200 Battery voltage Faulty signal
P0561 ECM-800B System relay Signal too low
P0562 ECM-820D Battery voltage Signal too low
P0563 ECM-820C Battery voltage Signal too high
P0564 ECM-930B Control module, communication fault Signal missing
P0571 ECM-900B Brake pedal sensor Signal missing
P0573 ECM-900C Brake pedal sensor Signal too low
P0579 ECM-9300 Control module, communication fault Faulty signal
P0580 ECM-930D Control module, communication fault Signal too low
P0581 ECM-930C Control module, communication fault Signal too high
P0602 ECM-5110 Malfunction indicator light CEM Faulty signal
P0604 ECM-9970 Memory error RAM Faulty signal
P0605 ECM-9980 Memory error ROM Faulty signal
P0606 ECM-9990 Engine control module (ECM) Faulty signal
P0607 ECM-9800 Engine control module (ECM), torque signal Internal fault
P0607 ECM-9810 Engine control module (ECM), engine rpm Internal fault
P0607 ECM-9820 Engine control module (ECM), load signal Internal fault
P0607 ECM-983B Engine control module (ECM) Internal fault
P0607 ECM-983C Engine control module (ECM) Internal fault
P0607 ECM-983D Engine control module (ECM) Internal fault
P0607 ECM-9840 Engine control module (ECM) Internal fault
P0607 ECM-984B Engine control module (ECM) Internal fault
P0607 ECM-9860 Engine control module (ECM) Internal fault
P0607 ECM-720B Engine control module (ECM) internal fault Signal missing
P0607 ECM-9850 Engine control module (ECM) Internal fault
P0627 ECM-291B Fuel pump control module Signal missing
P0628 ECM-291D Fuel pump control module Signal too low
P0629 ECM-291C Fuel pump control module Signal too high
P0634 ECM-7010 Engine control module high temperature Faulty signal
P0634 ECM-7020 Engine control module high temperature Faulty signal
P0638 ECM-9270 Throttle unit Faulty signal
P0642 ECM-810D Power supply (5 volt) Signal too low
P0643 ECM-810C Power supply (5 volt) Signal too high
P0645 ECM-630B Air conditioning (A/C) relay Signal missing
P0646 ECM-630D Air conditioning (A/C) relay Signal too low
P0647 ECM-630C Air conditioning (A/C) relay Signal too high
P0650 ECM-660B Malfunction indicator lamp (MIL) Signal missing
P0650 ECM-660C Malfunction indicator lamp (MIL) Signal too high
P0650 ECM-660D Malfunction indicator lamp (MIL) Signal too low
P0668 ECM-700D Engine control module (ECM), Internal fault Signal too low
P0669 ECM-700C Engine control module (ECM), Internal fault Signal too high
P0700 ECM-5100 Malfunction indicator light TCM Faulty signal
P0700 ECM-5130 Malfunction indicator light TCM Faulty signal
P0700 ECM-513B Malfunction indicator light TCM Signal missing
P0727 ECM-330B Engine speed (RPM) sensor Faulty signal
P0805 ECM-910B Clutch pedal sensor Signal missing
P0806 ECM-9100 Clutch pedal sensor Faulty signal
P0807 ECM-910D Clutch pedal sensor Signal too low
P0808 ECM-910C Clutch pedal sensor Signal too high
P0863 ECM-512B Malfunction indicator light communication Signal missing
P1124 ECM-92B0 Throttle unit Faulty signal
P1124 ECM-92D0 Throttle unit Faulty signal
P1136 ECM-680B Cooling fan for control modules Signal missing
P1136 ECM-680C Cooling fan for control modules Signal too high
P1136 ECM-680D Cooling fan for control modules Signal too low
P1167 ECM-92CC Throttle unit Signal too high
P1167 ECM-92CD Throttle unit Signal too low
P1480 ECM-620B Engine cooling fan (FC) control module Signal too low
P1481 ECM-650D Engine cooling fan (FC) Signal too low
P1482 ECM-650C Engine cooling fan (FC) Signal too high
P1526 ECM-960C Engine control module (ECM), torque signal Internal fault
P1646 ECM-2450 Front heated oxygen sensor, bank 1 Faulty signal
P1646 ECM-245B Front heated oxygen sensor, bank 1 Signal missing
P1646 ECM-245C Front heated oxygen sensor, bank 1 Signal too high
P1646 ECM-245D Front heated oxygen sensor, bank 1 Signal too low
P1647 ECM-2550 Front heated oxygen sensor, bank 2 Faulty signal
P1647 ECM-255B Front heated oxygen sensor, bank 2 Signal missing
P1647 ECM-255C Front heated oxygen sensor, bank 2 Signal too high
P1647 ECM-255D Front heated oxygen sensor, bank 2 Signal too low
P2065 ECM-440D Fuel level sensor Signal too low
P2096 ECM-24BC Front heated oxygen sensor, bank 1 Signal too high
P2097 ECM-24BD Front heated oxygen sensor, bank 1 Signal too low
P2098 ECM-25BC Front heated oxygen sensor, bank 2 Signal too high
P2099 ECM-25BD Front heated oxygen sensor, bank 2 Signal too low
P2101 ECM-9240 Engine control module (ECM) Faulty signal
P2108 ECM-929C Engine control module (ECM) Signal too high
P2108 ECM-929D Engine control module (ECM) Signal too low
P2108 ECM-9290 Engine control module (ECM) Faulty signal
P2109 ECM-92E0 Engine control module (ECM) Internal fault
P2111 ECM-925C Throttle unit Signal too high
P2111 ECM-925D Throttle unit Signal too low
P2112 ECM-926C Throttle unit Signal too high
P2112 ECM-926D Throttle unit Signal too low
P2119 ECM-9280 Throttle unit Faulty signal
P2121 ECM-9700 Accelerator pedal position sensor, digital signal Faulty signal
P2121 ECM-970B Accelerator pedal position sensor, digital signal Signal missing
P2122 ECM-941D Accelerator pedal position sensor, digital signal Signal too low
P2123 ECM-941C Accelerator pedal position sensor, digital signal Signal too high
P2126 ECM-9400 Accelerator pedal position sensor, analog signal Faulty signal
P2127 ECM-940D Accelerator pedal position sensor, analog signal Signal too low
P2128 ECM-940C Accelerator pedal position sensor, analog signal Signal too high
P2131 ECM-9000 Brake pedal sensor Faulty signal
P2135 ECM-9200 Throttle position sensor Faulty signal
P2177 ECM-21EC Adaptive heated oxygen sensor control, bank 1 Signal too high
P2177 ECM-212C Adaptive heated oxygen sensor control, bank 1 Signal too high
P2178 ECM-21ED Adaptive heated oxygen sensor control, bank 1 Signal too low
P2178 ECM-212D Adaptive heated oxygen sensor control, bank 1 Signal too low
P2179 ECM-213C Adaptive heated oxygen sensor control, bank 2 Signal too high
P2179 ECM-21FC Adaptive heated oxygen sensor control, bank 2 Signal too high
P2180 ECM-213D Adaptive heated oxygen sensor control, bank 2 Signal too low
P2180 ECM-21FD Adaptive heated oxygen sensor control, bank 2 Signal too low
P2187 ECM-21EB Adaptive heated oxygen sensor control, bank 1 Signal missing
P2187 ECM-216C Adaptive heated oxygen sensor control, bank 1 Signal too high
P2188 ECM-21E0 Adaptive heated oxygen sensor control, bank 1 Faulty signal
P2188 ECM-216D Adaptive heated oxygen sensor control, bank 1 Signal too low
P2189 ECM-217C Adaptive heated oxygen sensor control, bank 2 Signal too high
P2189 ECM-21FB Adaptive heated oxygen sensor control, bank 2 Signal missing
P2190 ECM-217D Adaptive heated oxygen sensor control, bank 2 Signal too low
P2190 ECM-21F0 Adaptive heated oxygen sensor control, bank 2 Faulty signal
P2191 ECM-210C Adaptive heated oxygen sensor control, bank 1 Signal too high
P2192 ECM-210D Adaptive heated oxygen sensor control, bank 1 Signal too low
P2193 ECM-211C Adaptive heated oxygen sensor control, bank 2 Signal too high
P2194 ECM-211D Adaptive heated oxygen sensor control, bank 2 Signal too low
P2195 ECM-24B0 Front heated oxygen sensor, bank 1 Faulty signal
P2196 ECM-24BB Front heated oxygen sensor, bank 1 Signal missing
P2197 ECM-25B0 Front heated oxygen sensor, bank 2 Faulty signal
P2198 ECM-25BB Front heated oxygen sensor, bank 2 Signal missing
P2227 ECM-1130 Atmospheric pressure sensor Faulty signal
P2227 ECM-113B Atmospheric pressure sensor Signal missing
P2227 ECM-113C Atmospheric pressure sensor Signal too high
P2227 ECM-113D Atmospheric pressure sensor Signal too low
P2228 ECM-112D Atmospheric pressure sensor Signal too low
P2229 ECM-112C Atmospheric pressure sensor Signal too high
P2231 ECM-243B Front heated oxygen sensor, bank 1 Signal missing
P2232 ECM-2220 Rear heated oxygen sensor, bank 1 Faulty signal
P2234 ECM-253B Front heated oxygen sensor, bank 2 Signal missing
P2235 ECM-2320 Rear heated oxygen sensor, bank 2 Faulty signal
P2237 ECM-247B Front heated oxygen sensor, bank 1 Signal missing
P2238 ECM-2470 Front heated oxygen sensor, bank 1 Faulty signal
P2239 ECM-247C Front heated oxygen sensor, bank 1 Signal too high
P2240 ECM-257B Front heated oxygen sensor, bank 2 Signal missing
P2241 ECM-2570 Front heated oxygen sensor, bank 2 Faulty signal
P2242 ECM-257C Front heated oxygen sensor, bank 2 Signal too high
P2243 ECM-249B Front heated oxygen sensor, bank 1 Signal missing
P2247 ECM-259B Front heated oxygen sensor, bank 2 Signal missing
P2251 ECM-24AB Front heated oxygen sensor, bank 1 Signal missing
P2254 ECM-25AB Front heated oxygen sensor, bank 2 Signal missing
P2281 ECM-640C Turbocharger (TC) control Signal too high
P2281 ECM-640D Turbocharger (TC) control Signal too low
P2300 ECM-360D Ignition coil cyl 1, signal Signal too low
P2301 ECM-360C Ignition coil cyl 1, signal Signal too high
P2303 ECM-361D Ignition coil cyl 2, signal Signal too low
P2304 ECM-361C Ignition coil cyl 2, signal Signal too high
P2306 ECM-362D Ignition coil cyl 3, signal Signal too low
P2307 ECM-362C Ignition coil cyl 3, signal Signal too high
P2309 ECM-363D Ignition coil cyl 4, signal Signal too low
P2310 ECM-363C Ignition coil cyl 4, signal Signal too high
P2312 ECM-364D Ignition coil cyl 5, signal Signal too low
P2313 ECM-364C Ignition coil cyl 5, signal Signal too high
P2315 ECM-365D Ignition coil cyl 6, signal Signal too low
P2316 ECM-365C Ignition coil cyl 6, signal Signal too high
P2400 ECM-433B Leakage diagnostic unit, pump Signal missing
P2401 ECM-433D Leakage diagnostic unit, pump Signal too low
P2402 ECM-433C Leakage diagnostic unit, pump Signal too high
P2404 ECM-4360 Leak diagnostic unit Faulty signal
P2405 ECM-436D Leak diagnostic unit Signal too low
P2406 ECM-436C Leak diagnostic unit Signal too high
P2407 ECM-436B Leak diagnostic unit Signal missing
P240A E CM-431B Leakage diagnostic unit, preheating Signal missing
P240B ECM-431D Leakage diagnostic unit, preheating Signal too low
P240C ECM-431C Leakage diagnostic unit, preheating Signal too high
P2414 ECM-24C0 Front heated oxygen sensor, bank 1 Faulty signal
P2415 ECM-25C0 Front heated oxygen sensor, bank 2 Faulty signal
P2418 ECM-432B Leak diagnostic unit, valve Signal missing
P2419 ECM-432D Leak diagnostic unit, valve Signal too low
P2420 ECM-432C Leak diagnostic unit, valve Signal too high
P250B ECM-5500 Oil level Faulty signal
P250C ECM-550D Oil level Signal too low
P2510 ECM-8210 System relay Faulty signal
P2511 ECM-821B System relay Signal missing
P2626 ECM-246B Front heated oxygen sensor, bank 1 Signal missing
P2629 ECM-256B Front heated oxygen sensor, bank 2 Signal missing
U0001 ECM-A130 Communication control module Signal missing
U0002 ECM-E000 Communication control module Internal fault
U0073 ECM-E003 Configuration error Faulty signal
U0103 ECM-7300 Gear-shift position sensor Faulty signal
U0167 ECM-710B Communication Immobilizer Signal missing
U0401 ECM-A020 Configuration error Signal missing
U0426 ECM-7100 Communication Immobilizer Faulty signal
Another Copy of OBD to Volvo DTC conversion
- 1488 Views
Last post by WhizzMan
- 1155 Views
Last post by 93Regina
- 3256 Views
Last post by Sommerfeldt
- 34 Replies
- 4018 Views
- 24 Replies
- 12246 Views
