IPD sale Volvo Parts
96 850 ac issue
2forty
Year and Model: 850 1996
96 850 ac issue
Post by 2forty » Tue Jun 12, 2018 6:12 pm
My 96 850 AC works and blows cold, then quits. I turn it off for a minute or two then turn it back on and it works for awhile. I sometimes can get it to come back on by turning the switch to auto. It can work all day and then some days turn on and off many times. Does this appear to be the thermal switch acting up?
Thanks
2forty
Year and Model: 1999 V70T5, 2005 V70
Has thanked: 117 times
Been thanked: 382 times
Trinidad & Tobago
Re: 96 850 ac issue
Post by abscate » Wed Jun 13, 2018 4:45 am
The classic Volvo intermittent AC is caused by clutch gap wear. You can measure this and fix this cheaply by searching this Forum for ‘ bread clip fix’ or ‘ zip tie fix’
1 SWMBO for 30 years
2 Volvos
3 VWs
4 Careers
5 cats/dogs/gears
6 Perfect Ladies in waiting
7 Drivers
8 Boats- with a big pointy metal thing on top
1999 V70 T5M 56 2005 V70 NA M56 VWs BMW
Chuck W
Year and Model: 97 854 T5
Been thanked: 6 times
United States of America
Re: 96 850 ac issue
Post by Chuck W » Wed Jun 13, 2018 6:01 am
The "wire fix" has been working for us on both cars for a while now, also.
2forty
Re: 96 850 ac issue
Post by 2forty » Wed Jun 13, 2018 7:45 am
Thanks
rguzz
Year and Model: 1996 850 turbo
Re: 96 850 ac issue
Post by rguzz » Wed Jun 13, 2018 9:17 am
I got a couple of seasons out of the wire fix, then had to replace the compressor. It was the original, of course.
oragex
Year and Model: S60 2003
Has thanked: 71 times
Been thanked: 113 times
Canada
Re: 96 850 ac issue
Post by oragex » Wed Jun 13, 2018 9:33 am
If the gap is the issue, just remove the pulley (replace the bearing at same moment, use only a good brand) and remove one or two shims. There is no need to replace the whole compressor. Of course, the compressor may go bad for other reasons which will require replacing it, but for the gap issue just undo the pulley.
2003 2.4i S60 automatic 125k miles
DIY Volvo repairs videos https://www.youtube.com/playlist?list=P ... s0FSVSOT_c
rguzz
Re: 96 850 ac issue
Post by rguzz » Wed Jun 13, 2018 4:56 pm
I was never fully convinced it actually needed replacing, I'll never know now. All good until this summer, now less cold than last year, so something is up again. But just doesn't blow cool enough, no gap related symptoms. The OP sounds like a clutch-gap problem, yes.
Trinidad & Tobago
Re: 96 850 ac issue
Post by abscate » Wed Jun 13, 2018 6:42 pm
22 years is pretty good evaporator life if you haven't replaced it.
200-300 in parts, 10 hours stupid labor...beautiful cold AC
2 Volvos
3 VWs
4 Careers
5 cats/dogs/gears
7 Drivers
Clemens
Has thanked: 47 times
Been thanked: 24 times
Austria
Re: 96 850 ac issue
Post by Clemens » Thu Jun 14, 2018 12:36 am
OP, I´d start with the ziptie fix. You just need a few zipties of different size and thickness to finetune. And a feeler gauge.
If that fixes it, you can keep the zipties (I´ve had them in 2 of my cars for 2 years or so w/o problems) or reshim the clutch orreplace the compressor. If that doesn´t fix it (or the gap is within specs to start with) you might be low on R134 (refrigerant). Then I´d have a shop evacuate the system and check how much gas is left inside (after 2 years I had 400 grams inside, should have been around 750-800). Then refill and see if the AC works accordingly. If you lose the gas quickly you will need a new evap as abscate suggested.
Summer: 1996 855 R
Winter: 1994 855 T5M
Donor: 1995 854 10V
Who is online
Users browsing this forum: bmdubya1198, Jaumme, jeffsws, jimmy57 and 67 guests
