1999 S70 ABS Problem
Reinie
Year and Model: 1999 S70
Post by Reinie »
My 1999 S70 non-turbo Base (240K miles) has an issue with the ABS system going off on dry pavement. Mostly when turning to the right into a parking spot, but also when driving straight ahead. There is also a clack, clack, clack that comes and goes that is related to the ABS issue, and not a CV joint issue. I have replaced the ABS module long ago. The wheel sensors are original. Does this sound like a problem with a worn reluctor ring on the axle?
Year and Model: Many Volvos
Been thanked: 76 times
Post by Ozark Lee »
I had a similar issue on my daughter's '98 and it turned out it was a bad hub and the ring was not being held centered on the sensor.
Reinie
Post by Reinie »
Do you recommend replacing the entire axle, or try to remove and replace the ring. I’m leaning toward replacing the axle because the cv joint on that side has a lot of miles on it.
Has thanked: 2199 times
Been thanked: 1852 times
If you are going to replace it try to find a good used Volvo OE one over a rebuilt or aftermarket unit. Those are just going to give you grief.
Remove the axle from the hub and give it a really good look over. Check the ABS ring for rust and dirt in the groves and especially for cracks which can form with rust build up. Clear the hole for the ABS sensor and check the wire for damage and finally check the sensor resistance.
BEJinFbk
Year and Model: '98 V70 R
Has thanked: 94 times
Been thanked: 146 times
Post by BEJinFbk »
Reinie wrote: 12 Jun 2018, 21:19 My 1999 S70 non-turbo Base (240K miles) has an issue with the ABS system going off on dry pavement. Mostly when turning to the right into a parking spot, but also when driving straight ahead. There is also a clack, clack, clack that comes and goes that is related to the ABS issue, and not a CV joint issue. I have replaced the ABS module long ago. The wheel sensors are original. Does this sound like a problem with a worn reluctor ring on the axle?
Was the module replaced or repaired?
Reinie
Post by Reinie »
Replaced by a Volvo specific repair shop. Not sure if it was a remanufactured module. Seems to me it was.
