IPD sale Volvo Parts
1999 S70 Cruise Control Surging, solved with new axle and ABS ring Topic is solved
Reinie
Year and Model: 1999 S70
Post by Reinie » Tue Jun 12, 2018 9:42 pm
My 1999 S70 non-turbo, base, (240K miles) has an issue with the cruise control. It will set and hold speed, but it pumps the gas pedal really bad. I have a rebuilt Xemodex ETM with about 140K miles on it. When the original ETM failed, I had no cruise at all and dash lights on. Could the ETM be going bad again? I checked the vacuum line elbow on the end of fuel rail and it was good.
Year and Model: Many Volvos
Been thanked: 14 times
United States of America
Re: 1999 S70 Cruise Control, Pumps the Gas Pedal
Post by Ozark Lee » Tue Jun 12, 2018 10:32 pm
On a '99 the gas pedal shouldn't move at all when the cruise is engaged. The pedal has no physical mechanical connection with the throttle body, it is totally fly by wire. The pedal itself has only wires from a position sensor and it typically stays all the way out since the signal is a one way flow from the pedal to the ETM. There is no return signal that would adjust the pedal position electronically.
Perhaps I am misreading the question.
'99 V70XC - Nautic Blue
Reinie
Post by Reinie » Wed Jun 13, 2018 6:42 am
Your right, the pedal does not move, but the cruise constantly accelerates / decelerates back and forth to maintain speed. It’s super annoying.
Pater
Year and Model: S70 1999 2.5 20V
Netherlands
Post by Pater » Wed Jun 13, 2018 8:20 am
Is this problem similar as in my topic?
Is this light surging or heavily (speed increase/decrease)
viewtopic.php?f=1&t=85562&p=474073
Reinie
Post by Reinie » Wed Jun 13, 2018 8:34 am
Yes, I noticed your post. I have the same issue. Let me know if you solve it.
Reinie
Post by Reinie » Sat Aug 04, 2018 2:08 pm
SOLVED: This was caused by a broken reluctor ring on the front axle. Parts were covered under warranty from previous repair (Oreilly Auto Parts). $130 labor to replace the axle. This also solved my issue with abs brake deployment on dry pavement.
Who is online
Users browsing this forum: bootkast, configsys and 62 guests
