Just moved the other XC70 form the yard and need to move it back. Now, at the turn of the ignition to start, I hear continuous clicking until I release the key. This I feel would be the starter . . . right? Since am not ready to tackle that now, can I just do the connecting the Pin 87 to Pin 30 to start the car, just to move it back to the yard? If yes, how is that done. Maybe I did not search well enough, but, need a good instruction on how to do the pin connections and on which relay.
Thanks.
Connecting Pins 87 To 30 To Start Car - Continuos Clicking With Ignition
Oka
- Year and Model: XC70, 2001
- Has thanked: 9 times
- Been thanked: 4 times
2001 Volvo XC70/AWD/Auto/Turbo/146kMiles
2001 Volvo V70XC/AWD/Auto/Turbo/144kMiles
2002 Subaru Outback L.L. Bean/3.0/131K/AWD
2005 Volvo XC90/AWD/V8/Auto 111 Miles
2006 Toyota Sienna LE/AWD 93K
1985 BMW (E23) 735i(US)/AUTO/209K Miles (Parked since 2011)
1997 Mazda MPV/AUTO/4WD/173K Miles (Parked since 2008)
- RickHaleParker
- Been thanked: 979 times
If the starter is clicking, check the battery.
Active
Past
Past
Oka
I have the battery a full charge right before starting it again. I remember (maybe it’s a Volvo thingy) sometimes a new battery is some solutions. Though this battery is about six years old. Will try another battery. Will send an update. Thanks for the info.
- RickHaleParker
When you think you have a full charge, take the battery to Autozone and have them bench test it.
If the battery sat for a long time without a float charger, good chance it has a heavy build-up of lead sulfate crystals. It is possible to recover a newer battery from sulfation but, six years old ... the odds are not good but not impossible.
Active
Past
Past
Oka
I got another older battery, fully charged it and it started the XC. I have moved it back to the backyard to deal with it latter. Thanks for your info.
- RickHaleParker
Store the battery/batteries on float charge (trickle lowest amperage) as a peventive measure to avoid this problem again. I have taken batteries that where in bad shape and restored them with a long float charge. It might take weeks on float charge but it not like it is needed now.
Active
Past
Past
- 792 Views
Last post by louis_m_c
- 6655 Views
- 1641 Views
Last post by pedal2metal
- 329 Views
Last post by rcbooth
- 38 Replies
- 7561 Views
Last post by jreed
