I read this thread in its entirety since it seems I have the same problem but am still undecided on what I should do.
viewtopic.php?f=1&t=60815
Background: Owned this vehicle since 2013 w/150K miles and been enjoying it and doing all the work myself. Regular synthetic oil changes every 4K miles. Just went over 201K miles a few weeks ago. Before this, the only thing that doesn't work are the headlight wipers, both disconnected but 1 does work and I also have the replacement for the other but never bothered to install it.
Just 2 months ago, I had the rear driveshaft replaced. Timing belt was due for replacement in 4K miles so I was planning on doing that. Anyways, love the car but I know that my wife doesn't want me to sink a lot of money into it since at the end of the day, it's still an 18 y/o vehicle w/ 200K+ miles on it.
Problem: Yesterday, CEL came on with a P0303 (Misfire on cyl 3) so I performed a compression check (dry/wet)and here are the results: cyl 1=140/150, cyl 2=140/150, cyl 3=0/0, cyl 4=140/160, and cyl 5=60/70.
From what I read everything points to a burnt valve. It appears I can get a remanufactured head w/ a warranty from Clearwater Cylinder Heads in FL for $600. I never have done any major work like this but I am retired so I do have the time to learn from Youtube and do it myself. Just called my independent Volvo shop and am awaiting a quote but in the meantime, I am gathering what my options are.
1. Have the cylinder head replaced?
2. Have the engine re-built or replaced?
3. Sell it as-is?
4. Scrap it?
This site has been such a tremendous help and is where I get my knowledge and confidence to attempt to do the work myself.
Would love to hear everyone's opinion and advise.
2000 V70R Possible Burnt Valve - looking for advice
- wizechatmgr
- Has thanked: 45 times
- Been thanked: 128 times
I've used Clearwater Cylinder Heads on a VW previously and everything went well. You could also just take the head off and bring it to a local machine shop.
2023 Lexus RZ450e -66k
- Year and Model: Many Volvos
- Been thanked: 76 times
Having a machine shop rework the existing head is certainly an option, particularly since it wasn't a victim of a broken timing belt. I have not checked on the valves for a '99 High Pressure Turbo engine so I am uncertain as to the cost. On the 850s the HPT engines had very expensive, sodium filled, exhaust valves and the last time I checked they were over $20.00 / Valve. With a local rework you could just have the machine shop replace the bad valve (or valves as the case may be, I would have them replace any of them that show signs of burning) and have them re-seat the rest of them. You will want to replace all of the seals while it is there but a local machine shop could likely do it for less than the cost of Clearwater head.
Where a Clearwater head is economical is when the timing belt broke and a bunch of the valves got bent. It is also quicker to have the replacement head there ready to go as soon as you remove the old one but it doesn't sound like this is the sole mode of transportation for you and you can withstand a few days in the machine shop time wise.
While we have had generally good reviews from members that have used Clearwater we have also had some members with negative experiences. As with anything, you pays your money and takes your chances.
- Has thanked: 316 times
- Been thanked: 531 times
I would recommend either going with a rebuilt head from Clearwater or a similar company or having it reworked at a local shop. I certainly wouldn't scrap a 2000 R!
I don't think there's a need to rebuild the whole engine. Replacing it with a lower mileage engine is an option if you can get one for a similar cost to the head, but a B5244T2 isn't a common engine, and you'd probably have to go with a 2.3 B5234T3 out of a T5.
Then the final option if you really don't want to sink any more money into it, sell it as-is. Somebody like me would pick it up in a heartbeat! I just recently saved a 2000 R from being scrapped. Currently manual swapping it.
configsys
- Year and Model: V70R
- Has thanked: 2 times
- Been thanked: 5 times
Thanks for all the advice. I don't mind removing the cylinder head but I've never done that kind of work before and will need guidance. You're right about the B5244T2 being rare. When I called Clearwater they said I needed the engine number which I didn't have yet and when I got it, I realized they don't have it listed on their site. After reading this thread viewtopic.php?t=45884 it scares me a bit about proceeding with this task since I don't have the skills or afraid I'll just make matters worse.
'16 S60 AWD
'17 S60 (totaled)
'13 XC60 Polestar
'12 S60 T5
'04 XC90 (sold)
'02 S40
'00 V70R
'93 850 GLT (sold)
'13A DICE/VIDA
'17 S60 (totaled)
'13 XC60 Polestar
'12 S60 T5
'04 XC90 (sold)
'02 S40
'00 V70R
'93 850 GLT (sold)
'13A DICE/VIDA
- FLXC90
- Year and Model: 98 V70 T5
- Has thanked: 16 times
- Been thanked: 45 times
This is actually a straightforward mechanical operation. There are so many tutorials on R&R of the head, default is the truesoap version. You will have differences due to the CVVT hub. Robert just recently put out a video on rebuilding the head. Your concerns are the valve stem diameter, lifter type, and correct valves.
I would suggest to anyone with modest to moderate skills, take your time, research, pull the head yourself. Do as much disassembly as you can yourself. Then let a shop check the head for true, guides if necessary, seats if necessary.
You will need special tools to remove the valve springs.
Biggest concern while disassembling, meticulously keep track of what went where. Egg cartons or divided trays marked for which valve position 1-10 intake and exhaust.
Current Volvos:
A block of styrofoam or the like is helpful for marking and keeping valves in place.
Robert has a couple of great videos on this topic.
The head removal isn't too bad of a process. I've never done it on a white block, but I have done it on my old Saab 9-5, and it was actually pretty easy. Take your time, read over the writeups, watch some RobertDIY on Youtube, and you'll be set!
- Been thanked: 4071 times
Check the helper forum for any SLUTs nearby for moral support.
That didn’t write quite like I meant
- wizechatmgr
SLUTs - is that like a new kind of educational credential, similar to a PhD?abscate wrote: 16 Jun 2018, 19:27 Check the helper forum for any SLUTs nearby for moral support.
They may want you to think so.wizechatmgr wrote: 16 Jun 2018, 20:49SLUTs - is that like a new kind of educational credential, similar to a PhD?abscate wrote: 16 Jun 2018, 19:27 Check the helper forum for any SLUTs nearby for moral support.
