My '98 S70 is on it's last leg and I was changing the front left tire to put on the spare and I stupidly did not chock the rear wheel
and the car rolled forward and came down on the rotor. It broke the tie rod at the joint. My stupid question is can I drive the car for a short distance without causing any more damage?
Dumb question but need to ask
Mr. Detail
- Year and Model: 2002 V70 N/A
- Has thanked: 157 times
- Been thanked: 6 times
tryingbe
- Year and Model: None
- Has thanked: 1 time
- Been thanked: 26 times
Mr. Detail wrote: 16 Jun 2018, 09:57 It broke the tie rod at the joint. My stupid question is can I drive the car for a short distance without causing any more damage?
I wouldn't.
85 GLH, 367 whp
00 Insight, 72 mpg
00 Insight, 72 mpg
- RickHaleParker
- Been thanked: 977 times
Too high of risk to reward. Have it towed.
Active
Past
Past
- Been thanked: 4064 times
Maybe out to the street to get it towed, or 1000 yards to a local shop at 5 mph at 0300 hours.
If the tie rod separates, the wheel will flop inward and stop you short, hard.
Mr. Detail
abscate, the tie-rod is already separated from the lower point of contact. Kind of like a ball joint connection.
If it is snapped off inside the tie rod end, the car is stuck and needs towing.
If it broke the nut off, you could clamp it and crawl it somewhere, and I mean 5 mph or less.
FlyingVolvo
- Year and Model: 2000 V70XC
- Has thanked: 51 times
- Been thanked: 74 times
Nah.
2000 V70XC - 340,000 miles
2023 V60 T8 PE
2023 V60 T8 PE
- 2352 Views
Last post by j-dawg
- 1707 Views
Last post by precopster
- 1962 Views
Last post by Craigd2599
- 2453 Views
Last post by shiloh51933
- 2109 Views
Last post by BrianV70
