Hello -
I have a 2008 C30 whose AC gets warm after 20 minutes of operation. I already did the clutch shim check and the clutch does not disengage yet the air blows warm. Refrigerant pressures are good, so it points to a bad evaporator temperature sensor. Online manuals show it being on the side of the evaporator above the gas pedal (LHD cars), but it is not there....
Can anyone clue me in as to where the C30's evaporator temp sensor is?
C30 Evaporator Temp Sensor Location - Where? Topic is solved
- RickHaleParker
- Been thanked: 979 times
Active
Past
Past
flamefront
- Year and Model: 2008 C30
Perfect. Thanks for posting that - I see that it is much higher up than I was looking.
Really appreciate the help
- 11 Replies
- 9050 Views
Last post by oragex
- 1740 Views
Last post by rmojica
- 1263 Views
- 7898 Views
Last post by beaters4ever
- 1370 Views
