Good evening,
Battery not getting the charge from alternator??
Alternator, Battery, Ground?
jimmy57
- Has thanked: 5 times
- Been thanked: 322 times
The alternator needs a power feed on the small gauge wire in order to begin to charge reliably. This power feed is through the warning light circuit. If the cluster is not working and there is no alternator light function and no charging can result.
Parts of the cluster works fine, but some of it doesn't. I have owned the car for about 4 years with no problem with the charging system. Then about 4 or 5 weeks ago it all started. Would I find that power feed wire underneath the dash on the driver's side? I am getting ready to start a new job and really would like to figure this out before I start.
Thank you for your reply and idea. That sounds like what is going on.
- 93Regina
- Year and Model: 93:240/940
- Been thanked: 65 times
Two items:
1. Ground strap to alternator....
2. Instrument Alt light power feed to alternator.
If both are hooked to alternator, then no wiring issue. If ground strap/wire is not hooked up, then you have a problem. If alt's warning light bulb is not working, then power can not be sent to alternator to energize it.
You don't need a RPM gauge...I do this all the time with my 93-245....take up RPM to around 2,300, and idiot light lits up brightly....which means in this vehicle, alternator is working.
Bosch OEM alternator works this way, if ground strap is hooked up. If your idiot Alt light is never seen, most likely it needs to be replaced.
- 93Regina
Three wires for a Bosch...Ground, Battery Hot, and indicator light wire.cracra wrote: 20 Jun 2018, 21:54Sorry so how many wires should be coming off back of the alternator?
Kurt Vonnegut says, “In this world, you get what you pay for.”what if I didn't buy a Bosch OEM?
It is possible, but there is more to go wrong:could it be the voltage regulator
ALTERNATOR & REGULATOR
Article Text 1990 Audi 100
So, have it tested...2nd one I bought brand new
- 3005 Views
Last post by RickHaleParker
- 17 Replies
- 29999 Views
Last post by Speedwagon55
- 942 Views
- 20 Replies
- 7789 Views
Last post by tonie
- 3917 Views
Last post by 240bri
