Intermittent electrical problems: power windows and A/C
kumulipo
- Year and Model: 1999 S70
- Has thanked: 7 times
Having problems with power windows from time to time. Turning the engine off and on usually restores function. A/C now doing the same thing. Suggestions? Thanks!
- wizechatmgr
- Has thanked: 45 times
- Been thanked: 128 times
Ignition switch or bad relays would be my first thoughts.
Pull and check the relays in the small fuse box (assuming yours is like my v70)
You may find some are badly in need of cleaning with a wire brush or just outright are ready for replacement.
Note that I'm not an expert by any means with the S series.
kumulipo
Thanks for your reply. I've been away for a few days, hence my delay in responding. I will check things out! BTW, the S70 and V70 seem to be the same thing, just finished differently aft. Cheers!
- 2877 Views
Last post by robotarmy
- 558 Views
Last post by wizechatmgr
- 1323 Views
Last post by StupidS80
- 1181 Views
Last post by LH707DE
- 585 Views
Last post by BEJinFbk
