Drivers door module date of maunufacture
- darylrobert
- Year and Model: V70 240 740t xc70
- Has thanked: 6 times
- Been thanked: 44 times
Date of manufacture for this ddm is 2001?
chrism
- Year and Model: S80 / 2005
- Has thanked: 7 times
- Been thanked: 89 times
I'm not sure about the "01" being the a date code or not, but you may be right. If you are trying to match up a replacement DDM, I went through that exercise. My V70 is 2003. I found a DDM in a 2003 S60 and the first two lines matched.
In your case that would be:
861327
01 W09E
The replacement worked for me even though the long number on the third line didn't match.
What's yours doing or not doing?
861327
01 W09E
- yagger
- Year and Model: V60 2016
- Been thanked: 39 times
xxWyyz
xx - Model Year
yy - Week of Manufacture
ex. 01W09E - 2001 Model Year, Week 9 (Feb 22 - 28)
ex. 03W016 - 2003 Model Year, Week 1 (Jan 1 - 7)
xx - Model Year
Volvo electronic expert
Online Data Transferring Service for Volvo modules
- darylrobert
Thankyou i just ordered on off ebay, the part number and year match my faulty unit but the week doesnt. I hope it will work as the faulty unit 'clicks' when its cold and i cant use the windows or mirrors until it stops clicking. i have replaced the little relay last winter and it worked great during the summer but its now getting cold and its playing up again.
- darylrobert
UPDATE i fitted drivers door module on my 2001xc70 with same part number and year (ebay seller said ddm removed from an S80) and it works without programming. just remove the door module fuse, i accidentally removed the wrong fuse and now have an 'airbag warning' light.
chrism
Good or bad, I didn’t pull the fuse when I replaced mine.
You may have to get a dealer or well-equipped indie shop to clear the airbag fault. I don’t know if VIDA will clear it or not.
- br0dy519
- Year and Model: 2004 XC70
- Has thanked: 132 times
- Been thanked: 126 times
On that note. To clear the SRS message, is it the same procedure as clearing other fault codes in VIDA? I think it’s in the diagnostics, erase, then you have to shut the engine off, on, rev it, off again? Theres an old lady with an 01 that I met the other day that I want to help out. Just wasn’t sure if it was a special procedure.
04s60 2.4
04xc70 2.5t
04xc70 2.5t
- 3522 Views
Last post by td2903
- 24 Replies
- 4590 Views
- 1958 Views
Last post by misha
- 5182 Views
Last post by Bragg Creek
- 563 Views
Last post by PiRX
