I've got a 2002 V40 that I'd like to add fog lights too. The car has a factory fog light switch that controls the rear fog lights, but it has no front fog lights.
I've been looking for information about adding a set of fog lights and have not found anything. I haven't started looking at wiring yet either. I'm hoping I can pull a set of factory lights from another v40 and that a wiring harness might already be in place.
Has anybody done this before, and does anybody have a link to a write-up? Thanks!
Adding fog lights to a 2002 V40
volvobydefault
- Year and Model: 2002 V40
- Has thanked: 1 time
- alschnertz
- Year and Model: 1995 854T
- Has thanked: 2 times
- Been thanked: 12 times
I have no experience adding fog lights, but I suspect the car is already wired for them.
Pull the covers in the lower bumper and see if there are wire connectors there.
Also, pull the plastic dashboard knock-outs that are near the rear fog switches and see if there are plugs there.
There may be an additional relay or fuse to utilize.
'84 Prelude
'06 MPV
'13 Ford Focus SE
'84 Prelude
'06 MPV
'13 Ford Focus SE
I actually installed fog lights on my 2003 volvo s40, and replaced the light switch box in the dash with one that has the Front Fog Light button... no work
. Right now i haven't had a chance to do much, but i am going to make my own switch and use a relay and a resistor to make the connection to the fog lights from a 12v source. I'll figure it out and post anything i can on here.
volvobydefault
When you installed the fog lights, did you find any unused plugs for them as part of the factory harness?
- 1231 Views
Last post by RichCrewe
- 535 Views
Last post by rohran
- 1570 Views
Last post by MadeInJapan
- 3471 Views
Last post by BEJinFbk
- 2356 Views
Last post by msyverts
