passenger seat belt pulled all the way out and wont go back
amacbabe
Year and Model: 2004 XC70
Post by amacbabe »
My passenger seat belt pulled all the way out and won't go back. Wondering how I get the covering off around the seat belt to look at everything inside. I called the dealer and asked about it and they said it may need a new tensioner and that would cost about $800 to $900. Thought I would try to see what I can do before going this rout- If anyone can tell steps on how to remove the covering and if I can solve
MDK
Year and Model: 2004 S60R
Been thanked: 42 times
Post by MDK »
MDK here. If you're saying the belt won't retract into the door pillar...then ya .. I know what you mean. I've had that happen before. The cover itself just snap locks into place. Pretty simple really. Sometimes they just get hung up. Try pulling the belt out as far as it will come and it might just be stuck a little bit. I worked on one for about 15 minutes before it finally decided to retract.... unless the spring is busted... which I doubt
chrism
Year and Model: S80 / 2005
Has thanked: 7 times
Been thanked: 89 times
Post by chrism »
Mine did that. I can’t recall exactly what it all looked like inside but I know I had to buy another pyrotechnic unit from a scrapper. Come to think of it I believe I had to replace the entire belt with it???? (Over five years ago.) It wasn’t rocket science but if you start messing with the tensioner or wiring, be sure to disconnect the battery - just in case.
Has thanked: 1609 times
Been thanked: 4065 times
I guess it kind of is rocket science.... :D
chrism
Post by chrism »
abscate wrote: 27 Jun 2018, 04:09 I guess it kind of is rocket science.... :D
Good one!
I guess if you're not careful it DOES become rocket science real quick, doesn't it!
amacbabe
Post by amacbabe »
Hi There- I was able to get the trim off and discovered the cap on the coil(tensioner) had come uncoiled) Can I just get this coil or do I need to replace the whole unit?
MDK
Post by MDK »
I would say at this point.... without seeing it. You should replace the whole unit. If disconnect the battery an before... they say that the SRS . will discharge and won't go off. You'll probably have to unblock the buckle from the seat. I believe that is a T 44 torx bit. I had do that when I replaced the seats in an 850 wagon I used to have. You'll be fine, take your time.MDK
