volvo 855T p0172 p0131, O2 sensor?
henrysin44
Year and Model: 1994 Volvo 855 Turbo
Has thanked: 2 times
Been thanked: 3 times
Post by henrysin44 »
My car has been running very rich and acceleration is less than usual. If I do a computer reset the car runs great for a day then back to running rich and sluggish. The MAF is good or I have 3 bad MAFs lol, I've checked all vacuum hoses, and replaced the temp sensor. I'm going to buy a new Bosch O2 sensor tomorrow unless theres something else I should look for.
Daily driver Black 1994 Volvo 855 2.3L Turbo - manual swapped, turbo swapped, green injectors, custom M4.4 Tune, de-catted, custom two-tone interior, V70R seats & rims
Teal 1994 Volvo 855 2.5L N/A Manual Transmission (the back up daily and parts car) - Runs and Drives but the engine knocks
Silver 1997 Honda CRV 2.0 AWD - its in a very sorry condition, but drives
Silver 2003 Subaru Forester 2.5L N/A AWD - Leaks everything
RickHaleParker
Been thanked: 980 times
Post by RickHaleParker »
How are you coming up with P0172 and P0131 on a '94 855T?
'94 had the black box blink codes and the codes are in the format X-Y-Z.
Active
Past
henrysin44
RickHaleParker wrote: 03 Jul 2018, 00:37 How are you coming up with P0172 and P0131 on a '94 855T?
Guess my 94' is weird, I have the blink box and the OBD II port. It is the late model 94'.
RickHaleParker
You might want to get a better scan tool. I suggest a Bluetooth ELM357 version 1.4 or higher and 850 OBD-II if you have an Android phone or tablet.
Did you smoke test the EVAP system? It easy to miss a leak just looking around.
Did you clear the codes and see what comes back?
EFI-231 EFI-232 (P0172) Long-term fuel trim. UPPER LIMIT
EFI-231 Long-term fuel trim, part load EFI-232 Long-term fuel trim, idling speed
Diagnostic trouble code (DTC) information EFI-231, EFI-232
Condition
The engine control module (ECM) receives information from the heated oxygen sensor (HO2S) about the fuel/air mixture in the idling and partial load ranges. If the fuel/air mixture deviates from λ=1 the short-term fuel trim will compensate for this by adjusting injection time so that λ=1 is achieved. When the short-term fuel trim makes an adjustment, the integrator median must be adjusted by the long-term trim. If adaptation needs to adjust to close to its maximum diagnostic trouble code (DTC) EFI-232 (idling range -0.48 ms - 0.40 ms) or diagnostic trouble code (DTC) EFI-231 (part load range factor 0.773 - 1.227) and the status message Upper limit (lean fuel/air mixture) or Lower limit (rich fuel/air mixture) will be stored.
Substitute value
none.
Possible source
  • Upper limit:
    defective mass air flow (MAF) sensor
    low fuel pressure
    air leakage
    faulty sensor signals.
Lower limit:
  • defective mass air flow (MAF) sensor
    high fuel pressure
    leaking injectors
    leaking evaporative emission (EVAP) system
    contaminated engine oil
    oil level too high
Fault symptoms
can result in high fuel consumption
may result in poor performance.
EFI-212 (P0131) Front heated oxygen sensor (HO2S). Signal too high. Permanent fault
Diagnostic trouble code (DTC) information EFI-212
EFI-212 Front heated oxygen sensor (HO2S), signal
Condition
Before fuel trim starts the front heated oxygen sensor (HO2S) must be ready - it should be at operational temperature and have the correct output voltage. Monitoring of the heated oxygen sensor (HO2S) function starts approximately 3 minutes after heated oxygen sensor (HO2S) heating starts. Diagnostic trouble code (DTC) EFI-212 is stored if there is a fault in the front or rear heated oxygen sensors (HO2S) or their cabling that affects the output voltage from the front heated oxygen sensor (HO2S).
Substitute value
fuel trim disabled
three-way catalytic converter (TWC) diagnostic disabled.
Possible source
Signal too high:
  • short-circuit to supply voltage in front heated oxygen sensor (HO2S) signal cable (+)
    short-circuit to supply voltage in front heated oxygen sensor (HO2S) signal cable (-)
    short-circuit to supply voltage in rear heated oxygen sensor (HO2S) signal cable (+)
    short-circuit to supply voltage in rear heated oxygen sensor (HO2S) signal cable (-)
    defective front heated oxygen sensor (HO2S)
    defective rear heated oxygen sensor (HO2S).
Signal too low:
  • short-circuit to ground in front heated oxygen sensor (HO2S) signal cable (+)
    short-circuit to ground in front heated oxygen sensor (HO2S) signal cable (-)
    short-circuit to ground in rear heated oxygen sensor (HO2S) signal cable (+)
    short-circuit to ground in rear heated oxygen sensor (HO2S) signal cable (-)
Signal missing:
  • open-circuit in signal cable (+)
    open-circuit in signal cable (-)
    defective front heated oxygen sensor (HO2S).
Faulty signal:
  • short-circuit between signal cable (+) and signal cable (-)
Fault symptoms
none.
Active
Past
Has thanked: 1611 times
Been thanked: 4072 times
The heater failure may well be tripping the OXS code, sortsupply, fuse, wiring, and connector before changing OXS
henrysin44
RickHaleParker wrote: 03 Jul 2018, 05:45 You might want to get a better scan tool. I suggest a Bluetooth ELM357 version 1.4 or higher and 850 OBD-II if you have an Android phone or tablet.
Condition
Substitute value
none.
Possible source
  • Upper limit:
    low fuel pressure
    air leakage
Lower limit:
    high fuel pressure
    leaking injectors
    oil level too high
Fault symptoms
Condition
Substitute value
fuel trim disabled
Possible source
Signal too high:
Signal too low:
Signal missing:
Faulty signal:
Fault symptoms
none.
I have an ELM but no idea where it went....or who 'borrowed' it :( . I did the carb cleaner test on every hose, elbow, and connection with no change in idle (also sprayed around the fuel rail). I also unplugged the MAF and drove around, it seemed to drive worse and when I plugged it back in the engine stalled out so I think its not the MAF.
I have a bunch of ECUs laying around and put a different one in and the O2 code came up instantly, the fuel trim code diddn't come back but that one took a day to pop up.
