IPD sale Volvo Parts
No Sparks... No Idea what to do... Topic is solved
Year and Model: 1999 V70T5, 2005 V70
Has thanked: 129 times
Been thanked: 399 times
Trinidad & Tobago
Re: No Sparks... No Idea what to do...
Post by abscate » Fri Jul 13, 2018 2:55 pm
Good use of the jumper cable. So your coil has 12 volts but no spark.
Either the ECU is not grounding it on command (which can be for many reasons which you can't troubleshoot easily) or the coil is bad.
Remove the negative terminal from the battery.
Disconnect everything from the coil and measure the resistance across the primary and the secondary side. If you need help with this just ask. You do need a voltmeter for this step.
1 SWMBO for 30 years
2 Volvos
3 VWs
4 Careers
5 cats/dogs/gears
6 Perfect Ladies in waiting
7 Drivers
8 Boats- with a big pointy metal thing on top
1999 V70 T5M 56 2005 V70 NA M56 VWs BMW
Dmck
Year and Model: 1995 850
United States of America
Post by Dmck » Fri Jul 13, 2018 2:57 pm
Open up fuse box and make sure the 15 in the number 1 spot isn't blown
Dmck
Post by Dmck » Fri Jul 13, 2018 2:59 pm
Maybe it's just bad timing and the coil died after your work.. I just hate when the problem doesn't line up with work done.
shihabafi
Has thanked: 39 times
Post by shihabafi » Fri Jul 13, 2018 3:03 pm
...Right, sooooooo... how do I do that exactly...?
What do you mean primary and secondary side?
SuperHerman
Been thanked: 76 times
Post by SuperHerman » Fri Jul 13, 2018 4:30 pm
I am having issues on my Range Rover - and to test whether I had spark I picked up an ignition coil tester. Basically it is a light that has one end that plugs into the spark plug and the other end into the coil. If the coil is working you will see it flashing when the engine runs. I paid $20 for mine at Advanced Auto Parts, but saw some for as low as $10 on line.
Nice thing about it is no chance of destroying a coil and you don't need a helper.
Good tool to have.
Trinidad & Tobago
Post by abscate » Fri Jul 13, 2018 6:29 pm
Here is a start...apologies i don’t have coils left on my Cars anymore
How a coil works. We flow current through the primary side, from the 12 Volts and then grounded through the ECU. When the ECU decides it’s the right time. It opens the circuit and the current flow comes to a crashing halt. It’s the change in current whichinduces a large voltage , like 20,000 Volts, in the secondary (far wire) that goes tomtheplugs.
A good coil has to pass current through the primary , the two small connectors, so a resistance of a few Ohms is right
The secondary can’t pass hardly any current, so it’s reistance to ground has to be high , like 20,000 ohms
When you report 12 Volts on your secondary, something is wrong
https://m.wikihow.com/Test-an-Ignition-Coil
2 Volvos
3 VWs
4 Careers
5 cats/dogs/gears
7 Drivers
dj_v70
Year and Model: v70 2003
Has thanked: 2 times
Been thanked: 14 times
Post by dj_v70 » Fri Jul 13, 2018 6:31 pm
shihabafi wrote:
Fri Jul 13, 2018 12:59 pm
Just to clarify, when you say to take a test lead, do you mean like, with a multimeter? Or should I just grab any wire and use it as a bridge of some sort?
Also, just took the black ends of my jumper cables and hooked one end on to the end of a spark plug which was connected to a wire connected straight to the ignition coil (bypassing the distributor), and the other end to the negative of the battery, and I got no spark...
Take any wire and connect negative side of coil to ground. Just touch it quickly, don't leave it there. Leaving it there for a long time could kill your coil.
Did you check resistance of the wire between spark plug and coil? It should be < 10kohms.
Still wish I knew for sure whether 11V was right answer from negative side of coil to ground. If so, it has to be your coil or the wire to your plug, or you aren't looking close enough for the spark. Spark can be missed sometimes on a bright day with the engine shaking as it is cranked. It is best to do it at night or with a helper. The coil test above is easier to verify because the engine isn't shaking and you can even hear the zap of the spark.
Dmck
Post by Dmck » Fri Jul 13, 2018 7:20 pm
Also if you get to the junkyard get another cam sensor if available. It's possible you cutting the bolt off did something to it
Trinidad & Tobago
Post by abscate » Sat Jul 14, 2018 2:03 am
Someone is cranking the engine while you are looking for spark, right? Is it spinning over nicely and sounds normal?
2 Volvos
3 VWs
4 Careers
5 cats/dogs/gears
7 Drivers
shihabafi
Post by shihabafi » Sat Jul 14, 2018 6:38 am
Fuse # 1 is nice and clean.
Okay so I don't know if I did anything wrong, but I followed the procedure on doing a bench test. When I touched the right stuff, I didn't get any readings. I'm thinking that I must be touching the wrong stuff... Should I be touching the terminals on the connectors and not the red and blue wires?
yes, there are no abnormal sounds, just can't get sparks...
I tried it, but got no sounds or sparks of any sort. Here's some pics from the setup.
I grounded it hovering about less than a centimeter from the engine block, and then used the other end of the jumper cable to tap the negative and then positive end of the battery...
Yes, I did check the resistance of the wires. I also took pictures of that... Safe to assume that's not the issue...
Who is online
Users browsing this forum: Bikertrash00, Cookeh, Eddystone, evolutionarywar, misha, Sommerfeldt, tardcart and 89 guests
