I've been all over multiple sites investigating this so bear with me:
Broke passenger side halfshaft a few weeks ago. Had it running in the parking lot where it happened. Towed it home. R&R half shaft and front axle brake job. Now I have a crank, no start situation.
*Fuel pressure good
*Good spark
*New cam and crank sensors (wires chaffed)
*Compression170-180 on all but #3 120-130
*Dumped a bit of oil in #3
*runs on starting fluid
*Battery voltage is good
*Fuel pump relay is new, jumped it as well
*Tested every fuse with multimeter(ohms)
I am at a loss here anyone have any ideas?
1998 S70 T5 turned into a brick
- wizechatmgr
- Has thanked: 45 times
- Been thanked: 128 times
Does it smell like unburnt fuel at the exhaust? If not, then the injectors are likely not firing.
- wizechatmgr
Double check those cam and crank sensors, if I remember correctly, one (or both) of them is required to pulse the injectors. Verify signal output from them. Are they OEM or aftermarket?
- SuperHerman
- Been thanked: 207 times
You state it runs on starter fluid. Have you looked at the fuel pump and/or fuel filter? Can you hear the pump turn on?
I would think that if the mentioned sensors were bad it wouldn't fire with starter fluid.
- Clemens
- Has thanked: 498 times
- Been thanked: 228 times
It could have nothing to do with each other. Might be fuel pump/injector related just from sitting.
1996 855 R,
2010 V70 D5,
2010 V70 D5,
precopster
- Year and Model: Lots
The fact it starts on starter fluid means it has to be a fuel issue.
dspran
- Year and Model: 1998 S70 T5
- Has thanked: 1 time
Fuel filter is less than 1000 miles old. Pump is good.SuperHerman wrote: 08 Jul 2018, 22:52 You state it runs on starter fluid. Have you looked at the fuel pump and/or fuel filter? Can you hear the pump turn on?
- 800 Views
Last post by volvolugnut
- 2260 Views
Last post by esl_97_850_T5
- 26 Replies
- 5249 Views
Last post by rguzz
- 15 Replies
- 2127 Views
Last post by BlackBart
- 708 Views
