IPD sale Volvo Parts
Worth Keeping 850 T5 ; transmission issues:{
Year and Model: Many Volvos
Been thanked: 29 times
United States of America
Re: Worth Keeping 850 T5 ; transmission issues:{
Post by Ozark Lee » Tue Jul 10, 2018 5:01 pm
I would back up and do a bit more diagnostic work. You indicated that you replaced the "shift selector module". I assume that you are referring to the PNP switch. If the PNP is not working properly or is out of adjustment that might explain the fact that you have no codes. I would be inclined to build a flash code reader and do more interrogation. There are also some service mode triggers that can be done via OBD-I to test the solenoids. Some OBD-II readers don't really do a very good job with the Volvo transmission and only post codes when the TCU post the fault back to the ECU.
Download the manual and go through some of the diagnostic procedures that are in the Automatic Transmission section:
http://www.matthewsvolvosite.com/downlo ... vo_850.zip
Some of those tests refer to a breakout box but you can get to the same signals directly from the connectors. It takes a bit of work with the schematics to figure out which wire to test but it is all there.
I check the fluid level with the car hot, idling in park, on a level surface. Check both sides of the dipstick since you can get a false reading on one side.
If the transmission is truly bad it is decision time and I guess it comes down to how well you like the car. My daughter's S70 blew the transmission but she was tired of it anyway so it went to the scrap yard. If you do buy a replacement transmission be sure it is from a turbo. The ratios are different between the turbo and the NA.
'99 V70XC - Nautic Blue
coodoo99
Year and Model: 1996
Post by coodoo99 » Tue Jul 10, 2018 7:42 pm
LOL...I'm working with a local Volvo shop and they found a good transmission with a 1 YR warranty. The total install would be 2300 with the tranny costing 800.
I'm leaning in that direction, I'm worried that if I try to change my tranny I'm mess something up. I just got done with the Rack and Pinon swap.
How hard was the manual tranny swap? I was thinking about going that route? I don't have room to pull the engine out and I watched that Robert Video on Youtube about his manual tranny swap.
How hard would it be to swap the tranny myself? I know is comes out the left wheel well and the sub frame needs to be dropped.
Has thanked: 5 times
Been thanked: 125 times
Canada
Post by scot850 » Tue Jul 10, 2018 11:01 pm
You could also try Chapman Motors Inc on Vancouver Island. Not had a bad part yet from them.
There is also vandsautodismantlers in Sacramento, CA.
As these cars are so hard to diagnose (96-98) in this case why not take it to a Volvo dealer and have the codes read? At least you would have a better idea of what may be the issue, we may be able to give better advice also. Hard to get there without the correct info. It could be something really basic as Lee suggests.
2006 XC70
2015 Kia Sportage EX-L
2000 V70 SE NA - New project and test bed - Sold
coodoo99
Post by coodoo99 » Wed Jul 11, 2018 7:39 am
I have the car at Larry's Volvo shop in Beacon Hill. They have some code reader that they use for transmissions prior to 1998. I was told they have the same diagnosis capability as a standard Volvo shop. Larry's a fair shop and I trust this shop and use them when I need that type of help.
Has thanked: 40 times
Been thanked: 118 times
Post by erikv11 » Wed Jul 11, 2018 7:49 am
Manual tranny swap: pretty tricky because you are installing many moving pars that weren't there before, however it is all documented pretty well on the internet if you need to read up beforehand and carefully gather together all the needed parts.
Automatic tranny swap: easiest out the top. Pull the engine and trans together, separate them, put them back together, put them back in. Not very tricky because you just take things out as opposed to taking things apart, but you need space for a hiost and have to be careful/safe moving the heavy objects.
A big danger in doing the auto trans swap yourself is the steering rack will be right there staring you in the face and sooooooo easy to get at, you will kick yourself for doing it earlier!
'96 855 NA, 140k
'98 S70 NA, 205k (living out west)
'98 V70, T5 tune-injectors-turbo, LPT engine, 275k
'06 S60 R, 155k
Year and Model: 1999 V70T5, 2005 V70
Has thanked: 130 times
Been thanked: 405 times
Trinidad & Tobago
Post by abscate » Wed Jul 11, 2018 8:06 am
$800 seems pricy for a used transmission. The warranty isn’t worth anything as the shipping and labor costs swamp the material cost.
They sell for $4/500 here
1 SWMBO for 30 years
2 Volvos
3 VWs
4 Careers
5 cats/dogs/gears
6 Perfect Ladies in waiting
7 Drivers
8 Boats- with a big pointy metal thing on top
1999 V70 T5M 56 2005 V70 NA M56 VWs BMW
sventastic
Year and Model: 1996 854R
Been thanked: 3 times
Canada
Post by sventastic » Wed Jul 11, 2018 11:22 am
I have mine for sale for $250CAD/$200USD... I had zero issues with it in my car, just no space to keep it around so I don't mind selling it cheap
Manual swap took me about 60-70 man hours, in case you're considering that route!
The car would actually be a fair bit quicker with the more aggressive final drive of the N/A auto transmission. The turbo auto trans ratios are stupidly long, not letting the car into boost til nearly 40km/h. At highway speeds the N/A only sits 200rpm higher in 4th gear
1996 854R | M56H | 16T | 255k
Who is online
Users browsing this forum: Cookeh, misha, Rubenrodri126 and 76 guests
