Volvo v70R 2003 wont start
cpozzer
Year and Model: Volvo V70 D5
Post by cpozzer »
Hi guys,
Can anyone help me out figuring out the issue?
The car has 144k KM, Timing belt done 3 years ago. Its a 6 speed manual.
[youtube][/youtube]
Volvo 850 1995 T5-R 2Litre 210HP "420.000KM"
Volvo V70 2002 D5 "315.000KM"
Volvo V70 2003 R "144.000KM" (Coming Soon)
chrism
Year and Model: S80 / 2005
Has thanked: 7 times
Been thanked: 89 times
Post by chrism »
It sounds like there's no compression. I'd pull the top timing belt cover and make sure the belt is OK.Then I'd check the compression, both dry and wet.
oragex
Year and Model: S60 2003
Has thanked: 102 times
Been thanked: 352 times
Post by oragex »
The crank speeds way too fast, much like when there's not spark plugs installed. Is it your car? Did the engine shut off all of a sudden? As above, it feels like the timing belt snapped (can happen with cheap timing belt parts) and the cam doesn't follow the crank causing no compression. Just undo the two torx screws on the upper engine cover, then release two clips and lift the cover.
cpozzer
Post by cpozzer »
Yup, no compression. The timing belt was loose and probably skipped 3 or 4 teeth. The engine is damaged, we will remove the head and see whats to be done.
Thanks
chrism
Post by chrism »
There may or may not be engine damage, depending on how far the belt slipped. Before you pull the head off you might want to borescope the cylinders to see if there has been any valve contact on the piston crowns. Maybe try looking at the belt, tensioner, idler, etc and see just how far off things are.
cpozzer
Post by cpozzer »
I do not think there is other damage, they just touched looking at the marks on the pistons
Has thanked: 1614 times
Been thanked: 4078 times
The pistons have marks on them even if the valves have not touched, so don’t pull that head. Reset the timing belt To the marks and check compression.
oragex
Post by oragex »
Don't forget to replace the PCV while there
chrism
Post by chrism »
abscate wrote: 13 Jul 2018, 03:16 The pistons have marks on them even if the valves have not touched, so don’t pull that head. Reset the timing belt To the marks and check compression.
Judging from the photo, it looks like the head is already off. So now what, fill the combustion chambers with solvent and see how fast they drain through the valves?
IF the heads are off, just do the valve and seal job.
It really does pay to do the compression test while it still together though.
