IPD sale Volvo Parts
Volvo v70R 2003 wont start
Help, Advice, Owners' Discussion and DIY Tutorials on Volvo's stylish, distinctive "P2" cars.
2001 - 2007 XC-70
cpozzer
Year and Model: Volvo V70 D5
Italy
Post by cpozzer » Tue Jul 10, 2018 9:00 am
Hi guys,
Can anyone help me out figuring out the issue?
The car has 144k KM, Timing belt done 3 years ago. Its a 6 speed manual.
Volvo 850 1995 T5-R 2Litre 210HP "420.000KM"
Volvo V70 2002 D5 "315.000KM"
Volvo V70 2003 R "144.000KM" (Coming Soon)
chrism
Year and Model: S80 / 2005
Been thanked: 13 times
Re: Volvo v70R 2003 wont start
Post by chrism » Tue Jul 10, 2018 11:06 am
It sounds like there's no compression. I'd pull the top timing belt cover and make sure the belt is OK.Then I'd check the compression, both dry and wet.
oragex
Year and Model: S60 2003
Has thanked: 74 times
Been thanked: 122 times
Canada
Post by oragex » Wed Jul 11, 2018 4:43 am
The crank speeds way too fast, much like when there's not spark plugs installed. Is it your car? Did the engine shut off all of a sudden? As above, it feels like the timing belt snapped (can happen with cheap timing belt parts) and the cam doesn't follow the crank causing no compression. Just undo the two torx screws on the upper engine cover, then release two clips and lift the cover.
2003 2.4i S60 automatic 125k miles
DIY Volvo repairs videos https://www.youtube.com/playlist?list=P ... s0FSVSOT_c
cpozzer
Italy
Post by cpozzer » Wed Jul 11, 2018 2:37 pm
Yup, no compression. The timing belt was loose and probably skipped 3 or 4 teeth. The engine is damaged, we will remove the head and see whats to be done.
Thanks
chrism
Post by chrism » Wed Jul 11, 2018 4:29 pm
There may or may not be engine damage, depending on how far the belt slipped. Before you pull the head off you might want to borescope the cylinders to see if there has been any valve contact on the piston crowns. Maybe try looking at the belt, tensioner, idler, etc and see just how far off things are.
cpozzer
Italy
Post by cpozzer » Fri Jul 13, 2018 2:44 am
I do not think there is other damage, they just touched looking at the marks on the pistons
Year and Model: 1999 V70T5, 2005 V70
Has thanked: 129 times
Been thanked: 399 times
Trinidad & Tobago
Post by abscate » Fri Jul 13, 2018 3:16 am
The pistons have marks on them even if the valves have not touched, so don’t pull that head. Reset the timing belt To the marks and check compression.
1 SWMBO for 30 years
2 Volvos
3 VWs
4 Careers
5 cats/dogs/gears
6 Perfect Ladies in waiting
7 Drivers
8 Boats- with a big pointy metal thing on top
1999 V70 T5M 56 2005 V70 NA M56 VWs BMW
oragex
Canada
Post by oragex » Fri Jul 13, 2018 7:33 am
Don't forget to replace the PCV while there
chrism
Post by chrism » Fri Jul 13, 2018 8:53 am
Judging from the photo, it looks like the head is already off. So now what, fill the combustion chambers with solvent and see how fast they drain through the valves?
Trinidad & Tobago
Post by abscate » Fri Jul 13, 2018 9:14 am
IF the heads are off, just do the valve and seal job.
It really does pay to do the compression test while it still together though.
2 Volvos
3 VWs
4 Careers
5 cats/dogs/gears
7 Drivers
Who is online
Users browsing this forum: mrjay62, rclapper, RickHaleParker, StickyPocket, XC70Rider and 52 guests
