ATF filter?
Mr. Detail
- Year and Model: 2002 V70 N/A
- Has thanked: 157 times
- Been thanked: 6 times
Does anyone know if my 2002 V70 has a automatic transmission filter? I believe it is the Aisin-Warner but not sure of the exact part number.
jimmy57
- Has thanked: 5 times
- Been thanked: 322 times
Yes. But it is not serviceable without transmission removal and partial disassembly. Primary filtration is sediment collection on bottom of case. Drive car and then immediately drain the transmission to get the bulk of the sediment out.
Mr. Detail
Thank you kindly Mr. Jim.
01_Nautic_V70
- Year and Model: 2008 XC90 V8
- Been thanked: 8 times
Yeah, easy to change once you have removed the transmission, split the bellhousing off of it and removed the pump assembly and clutch packs for 1-2.Mr. Detail wrote: 11 Jul 2018, 13:37 Does anyone know if my 2002 V70 has a automatic transmission filter? I believe it is the Aisin-Warner but not sure of the exact part number.
It's at the bottom the picture below.
Georgeandkira
- Year and Model: '07 V70 + '15 XC70
- Has thanked: 79 times
- Been thanked: 71 times
Can you say, "A 3/8" inline filter, please"?
Magnefine, WIX, ACDelco and others make 'em.
01_Nautic_V70
The inline filter in a cooler line works well. It won't help you if your sump filter is clogged, though.
- 11 Replies
- 11719 Views
Last post by STSCowboy
- 1137 Views
Last post by Mr. Detail
- 15 Replies
- 2968 Views
Last post by 454cid
- 3038 Views
Last post by boksalg
- 22 Replies
- 3675 Views
Last post by rspi
